Header bolts >
Header bolts
Header bolts
Old 05-28-2005 | 02:26 PM
Downtown42's Avatar
Default Header bolts
My CMI bolts need to be ck'd and tightened regularly.
Anyone use header bolts so they stay locked up? My neighbor suggested them but he is not a hi-perf boater, just bass boat dude.
Downtown42 is offline
Old 05-28-2005 | 03:10 PM
Strip Poker 388's Avatar
Rob
Default Re: Header bolts
I use the ARP stainless 6 point 3/8 x 1 inch .The reason most of the time for it loosing is the new gasket compressing. I used the Felpros Teflon coated steel shim and have only tightened them once after I ran it and got them hot.11 hours so far
Strip Poker 388 is offline
Old 05-28-2005 | 09:16 PM
Prowler's Avatar
Charter Member #1472
i put studs on most of mine,the ones you can't get a socket on.
Prowler is offline
Old 05-28-2005 | 10:32 PM
KAAMA's Avatar
I need some studs for my headers that I can put on the ends of my heads to at least make it a little easier to hang the header, and header gasket on. The rest I just use bolts. Does ARP make such a stud???
KAAMA is offline
Old 05-30-2005 | 09:22 PM
rbtnt's Avatar
Yes they do.
Here a link to SUmmit Racing and a part number I think you want is below.
http://store.summitracing.com/defaul...=egnsearch.asp
ARP-400-1413
rbtnt is offline
Old 05-31-2005 | 03:44 PM
I had the same problem with the bolts coming loose. I had to retighten a few every 10 hrs or so. I swithced to the ARP SS studs and have not found a loose one yet in 50 hrs.
They also look very nice
Griff is offline
Back4More
6
03-19-2006 11:26 AM
BadDog
1
03-03-2006 11:23 PM
RutRow
2
08-19-2004 09:03 AM
klaw
1
08-10-2004 12:39 PM
