Handling Problem! >
Handling Problem!
Handling Problem!
Old 05-29-2005 | 08:36 PM
n2boatn2's Avatar
Question Handling Problem!
Today I was cruising around 45 miles per hour and hit the sticks, brought up the trim, wot as it got on top of the water it took a jerk to the right on a slight angle,,then as I brought the sticks back and slowed down around 45 mph it kicked back to the left where it was originally,, this has never happened before,, the only thing different about today was I changed to 4 blades instead of my usual three blades. Any help in this manner any reasoning for this change in the handle would make me more comfortable on my next outing.
n2boatn2 is offline
Old 05-31-2005 | 03:07 PM
RJ1340's Avatar
Default Re: Handling Problem!
That's called handling characteristic. Remember it.
RJ1340 is offline
Old 05-31-2005 | 03:25 PM
Go back and try your 3 blade and see if it does it.
What boat???
Exactly what kinds of props are you running???
Most likely, its just a characteristic of the new prop.
Griff is offline
Old 05-31-2005 | 04:12 PM
ROGMAN's Avatar
Does your outdrive have any side to side slop or play?
ROGMAN is offline
Old 05-31-2005 | 04:37 PM
Tantrum's Avatar
What boat and prop are we talking about?
4 Blades can give more transom lift which may make it handle differently.
Tantrum is offline
Old 05-31-2005 | 04:42 PM
Dave M's Avatar
Veteran: Navy
That's what I was thinking. Could be a worn gimbal ring. Before I replaced my gimbal ring it would do what you described.
Dave M is offline
Potomac Fever
Velocity
31
08-15-2007 11:58 PM
epeek
Fountain
8
07-26-2005 11:15 AM
tj309
33
02-26-2005 06:16 AM
Tinkerer
07-11-2004 12:00 AM
jeffro
Scarab
3
08-19-2002 07:32 AM
