Fuel pressure fluctuations Procharger M-1 7.4 MPI >
Old 06-02-2005 | 08:33 AM
Default Fuel pressure fluctuations Procharger M-1 7.4 MPI
I have set my fuel pressure a number of times under way in order to achieve WOT with out faltering. Initial 4600RPM then backs down to 4200. The last attempt @ this adjustment got me to 4400 WOT but the fuel pressure would fluctuate wildly between 55#s and 46#s. Is this common or should it be more stable?
baronbob is offline
Old 06-02-2005 | 09:30 AM
Turbojack's Avatar
Default Re: Fuel pressure fluctuations Procharger M-1 7.4 MPI
If set up correctly fuel pressure is related to the amount of boost you are runing. I set mine with engine off at 43PSI, pressure goes down when engine in running & in vacuum, & goes up past 43 as boost goes up. At 10lbs of boost I have 53psi of pressure. Ths way the difference between the two is always the same.
Turbojack is offline
Old 06-02-2005 | 11:07 AM
Blow your vacuum line out and make sure it's not restrcted. Mine was acting up and it had oil in the line causing it not to activate the regulator.
kennyo is offline
DORaymond
24
05-26-2014 05:42 PM
Pat McPherson
13
07-07-2013 03:22 PM
mats
10
10-12-2005 09:54 AM
Lester
8
04-25-2004 04:47 PM
liquid asset
9
03-11-2003 06:27 PM
