Amsoil Marine gear lube >
Old 06-02-2005 | 06:16 PM
Default Amsoil Marine gear lube
Has anybody been using the Amsoil Marine gear lube. I want to try it but the stuff looks really thin. It is suposed to be a 80w-90 GL-4 weight oil but it looks alot thinner than other drive oils.
96f350psd is offline
Old 06-02-2005 | 07:43 PM
bob
Charter Member #40
Default Re: Amsoil Marine gear lube
I have about 5 hours on it in some #5's. No problems. Actually the slightly thinner viscocity may save some hp from being used to spin the drives.
bob is offline
Old 06-02-2005 | 09:06 PM
Hydrocruiser's Avatar
Arrow Re: Amsoil Marine gear lube
Originally Posted by 96f350psd
Has anybody been using the Amsoil Marine gear lube. I want to try it but the stuff looks really thin. It is supposed to be a 80w-90 GL-4 weight oil but it looks alot thinner than other drive oils.
Well it sure aint Series 2000 gear lube....the former was a heavily ester based formulation...
Hydrocruiser is offline
Old 06-03-2005 | 08:56 AM
using Mobil 1 and great so far....
kilroy is offline
Old 06-04-2005 | 10:31 AM
Sounds like a good choice to me as well.
Old 06-04-2005 | 11:06 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
I Was Using Series 2000 The New Stuff Looks To Thin To Me Also. I Realy Don't Like The Looks Of It.
WILDTHING TAZ is offline
Old 06-05-2005 | 09:45 AM
I have been using the Amsoil 80-90 gear oil now for about a year and a half. I run the boat hard and change oil every 50 hours. So far I have not had had any drive problems. (Knock on wood)
Don
Maritime_Eng is offline
Old 06-05-2005 | 07:34 PM
It may reduce drag and it may not. What kind of film strength does it have??
I truly liked Series 2000 lube....the new stuff I would like more data on.
Old 06-05-2005 | 08:53 PM
cuda's Avatar
Would these work in a Kaama drive also?
cuda is offline
Old 06-06-2005 | 10:22 AM
Wobble's Avatar
SORE MEMBER
Which Mobil-1 are you using? I believe there are 3 types available
Mobil 1 Synthetic Gear Lube LS 75W-140
Mobil 1 Synthetic Gear Lube LS 75W-90
Mobilube HD Plus 80W-90
Thanks,
Wobble is offline
