cam shafts for a HP 500 EFI, need help fast >
Old 06-03-2005 | 09:05 PM
boatinbill's Avatar
Registered User
Default cam shafts for a HP 500 EFI, need help fast
I broke a cam shaft on my '99 HP500EFI today. What cams should I replace them with. The motor is essentially stock, except it is bored 30 over with flat top SRP pistons.
I want to get it fixed fast so I do not miss much of the summer.
boatinbill is offline
Old 06-04-2005 | 08:13 AM
PatriYacht's Avatar
Default Re: cam shafts for a HP 500 EFI, need help fast
The stock one is probably the best one. It's already pretty wild for a 502. Call Crane for a replacement. I'm pretty sure they make it and they'll charge half as much as Merc.
PatriYacht is offline
Old 06-07-2005 | 10:48 AM
boatinbill's Avatar
Registered User
Just to close this out, after much discussion with many sources about whether the Crane cam is the OEM replacement, I got a Crane model 164621 cam from Teague Marine for around $350, Mercury wanted $860 for a replacement. According to Crane and Teague the 164621 is the OEM replacement cam. It is a billet cam with a press on distributor gear. Although I have not removed it yet, it appears the distributor gear is what broke on mine.
Old 06-07-2005 | 11:09 AM
PatriYacht's Avatar
Glad it worked out for you.
Old 06-07-2005 | 12:17 PM
boatinbill's Avatar
Registered User
Thanks for you input and steering me in the right direction.
Inspector
1
09-24-2007 09:46 PM
crayolacrazy
1
01-17-2007 08:44 PM
Strip Poker 388
9
09-25-2004 09:53 AM
220EagleXp
05-25-2002 10:04 PM
502 Magnum
2
04-22-2002 04:36 AM
