How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade? >
Old 06-05-2005 | 10:55 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?
I can see why Fred leaves his boat on the trailer now. Its CUSTOM now baby, you can't even SPECIAL ORDER one like this:
Attached Thumbnails How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?-first-look.jpg
Sydwayz is offline
Old 06-05-2005 | 10:56 PM
masher44's Avatar
Default Re: How much wood could a woodchuck if a woodchuck chucked a prop-blade?
masher44 is offline
Old 06-05-2005 | 10:57 PM
Outdrive1's Avatar
Masher touches my
I have one of those in my garage.....It belongs to Fountainatlast.
Outdrive1 is offline
Old 06-05-2005 | 11:04 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I felt a vibration as we were coming back into Deltaville, VA after the Rappahannock River Boaters Association Radar Shootout. DocManRich37 and his wife Jenn were with us, and MS was driving. As soon as we came off plane, what was remaining of the prop blade came off. It looks like it came loose and took one or two passes while still barely attached and pretty well chewed up the cavitation plate, annode, and pick-up for my drive shower.
Attached Thumbnails How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?-prop-day.jpg   How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?-cav-plate.jpg   How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?-cav-plate-off.jpg
Sydwayz is offline
Old 06-05-2005 | 11:07 PM
Outdrive1's Avatar
Masher touches my
make sure it didn't bend your propshaft as well.
Old 06-05-2005 | 11:10 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There is NO indication we hit ANYTHING. There is one ding on another blade, but I am pretty sure the ejected blade clipped it on the way to its new home. The enire lower is spotless. It appears to have just stress cracked and sheared its way off.
I have a replacement case in the garage already. Already shopping for props, lower is off the boat, and will be going to mechanic tomorrow for a once over, and gear/bearing swap to replacement case. I need to call Maxx Machine and get a new pick-up/hose. It could have been much worse. I was actually more pissed about losing my Oakleys earlier that day than this damage.
Attached Thumbnails How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?-all-three-broke.jpg
Sydwayz is offline
FOUNTAINATLAST's Avatar
Been there done that, that Sucks. Was it Labbed or just stock???
FOUNTAINATLAST is offline
Old 06-05-2005 | 11:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Actually, the entire propshaft, lower (aside from cavitiation plate), and carrier bearing look, appear, and feel fine. They are still going in for a 100% once over.
I think I would have rather blown another damn trailer tire. This REALLY needs to be the end of bad $hit this season. I know others have it much worse than me, but its been something every trip.
I will put the old lower case up for sale after a bit. Its still good for a beater or work boat.
Stock 28P B1.
(Now looking for a LH 28P B1 Stock)
Sydwayz is offline
Old 06-06-2005 | 12:49 AM
Clearly that is a manatee strike
Anarchy Powerboats is offline
Old 06-06-2005 | 01:01 AM
Default Re: How much wood could a woodchuck chuck if a woodchuck chucked a prop-blade?
Man a manatee did that??? We need to do something about all these manatees, there damaging our boats.
