looking,  bravo 24 or labbed 26 or 1.50 gears >
Old 06-08-2005 | 07:09 AM
gsmith9898's Avatar
Default looking, bravo 24 or labbed 26 or 1.50 gears
I need help. I have 1.36 gears and a 26 bravo. I can't get over 4800 rpm with my 525 efi. I have been told to get a labbed 26 or a stock 24 bravo or change my gears. Any body have the above they want to sell? I would rather just change props but the gears I could use for a spair if I went to a wipple I could put the 1.36 gears back in.
gsmith9898 is offline
Old 06-08-2005 | 10:29 AM
PatriYacht's Avatar
Default Re: looking, bravo 24 or labbed 26 or 1.50 gears
I may have a pair of 24's you can borrow if you are close by. Where do you live?
PatriYacht is offline
Old 06-08-2005 | 10:49 AM
I wouldn't change my gear ratio in your situation. There are plenty of props available that will give you the desired RPM. Just my .02!
WETTE VETTE is offline
Old 06-08-2005 | 02:59 PM
gsmith9898's Avatar
I'M IN TULSA OKLAHOMA.
Old 06-08-2005 | 03:24 PM
ali
If patriyacht does'nt work out ,I have a 4 blade 24 pitch bravo 1 with 2 hours of use. Perfect condition 300 inc. ground shipping
Jere [email protected]
760-717-5373
ali is offline
Old 06-08-2005 | 09:14 PM
gsmith9898's Avatar
thats it?
Old 06-09-2005 | 03:39 AM
If you're gonna change something, just get the props labbed and gain some performance with the change. Also, the least $$$.
Griff is offline
Old 06-09-2005 | 06:24 AM
Mr Gadgets's Avatar
Charter Member #601
I would try the prop swap. Less money. But if your drive is due for a freshen up.. then maybe that route. But find 1:5 gears is getting harder to do. Next step is do the X gear upgrade, that gives you all new upper parts.
I would try the $300 prop. Not that I am against the labbing process, but the blades get real thin when they are labbed and they dont do well in the gravel pits.. Besides, if you get the 24, you can have that labbed and save the 26 for when you move up to more horsepower.. which we all know everyone does at some point..
Dick
Mr Gadgets is offline
Old 06-09-2005 | 06:49 AM
gsmith9898's Avatar
I have the 525 efi and I called whipple yesterday to see about the upgrade. $10,000. So for now it looks like I'll be changing props.
Old 06-09-2005 | 07:14 AM
RLW
760-717-5373
That is a fair deal. What more do you want?
RLW is offline
