Motor surging above 3200 rpms >
Old 06-15-2005 | 08:30 PM
magnuman's Avatar
Default Motor surging above 3200 rpms
I have had a problem recently of my starboard motor surging at around 3200 rpms. This only happens under load (when I am running the boat).The boat will refuse to go past 3200-3500rpms. When the boat is in neutral it revs to 6200 rpms without a hiccup.
The engine in a 350 small block with mercury racing 700cfm carb.
So far I have checked distributor, replaced coil, rebuilt carb, checked fuel pressure from fuel pump..all this to no avail.
Any help appreciated as I running out of possibilities.
magnuman is offline
Old 06-15-2005 | 09:08 PM
Official OSO boat whore
Default Re: Motor surging above 3200 rpms
Sounds like a mixture problem to me. It's proably running fat or the engine would be backfiring.
Cord is offline
Old 06-15-2005 | 10:46 PM
Does your carb have the inline filter near the fitting from the fuesl line to the carb? I had an old donzi that did what you describe and my filters were plugged.
HOTTZU98 is offline
Old 06-16-2005 | 06:47 AM
J-Bonz's Avatar
could be air entering your fuel line or begining form of vapor lock
J-Bonz is offline
Old 06-20-2005 | 01:04 AM
magnuman's Avatar
Ttt
magnuman is offline
Old 06-20-2005 | 10:35 AM
Turbojack's Avatar
Swap Carbs between motors & see if problem moves to other motor.
Turbojack is offline
Old 06-20-2005 | 12:11 PM
I had a similar problem last year. Turned out my anti-siphon valve in the tank was bad. Hook up a portable tank to the fuel pump inlet. If problem goes away, that's probably the culprit.
Liberator21 is offline
txriverrat2001
2
05-01-2008 08:25 AM
Rocko C
Baja
11
09-25-2007 06:44 PM
Downtown42
04-20-2007 06:32 PM
BajaFresh
10-11-2003 05:09 PM
Miguel
6
08-14-2002 09:40 AM
