fuel lines
Old 06-17-2005 | 09:24 PM
fuel lines
My Motor Builder Is Just Finishing Up My New 454 Procharger Motors. He Is Telling Me I Need New Fuel Lines From The Tank. I Have 3/8 Lines He Says I Need 1/2 Lines. Problem Is Fittings In Tank Look Like There Welded In. Has Anyone Run Accross This Problem. How Do I Increase The Fuel Line Size Without Blowing My Self Up
electrical1 is offline
Old 06-17-2005 | 10:11 PM
articfriends's Avatar
Default Re: fuel lines
Ideally you need 1/2 fittings,but not always possible. I ripped the floor of my baja out 2 years ago to run bigger line to the tk,i was able to get rid of the anti-siphon restriction but with out replacing entire gas tank i couldn't plumb bigger fittings than 3/8 pipe thread into tk. I did bore out the fitting and polished it's i.d (it was a 3/8 by -10 an adapter) . I e-mailed you my phone #,feel free to call me w/any other questions i may help you with,I remember all the problems you had last year with those 454 ho's blowing up,i work from 5pm to 1 or 2 am in my shop here at home every night,best time to call,Smitty
articfriends is offline
Old 06-18-2005 | 07:09 AM
KNOT-RIGHT's Avatar
Here is a option your tank bung is Welded right?
This is what I did.
If it is A 3/8 female pipe thread. that is welded. Get a male
3/8NPT brass close nipple. I went to my local hobby shop and got 15\32 brass thin wall tubes which fit perfecly into a 3/8 brass nipple. Soldered them together.
These are about 14 inches long and slide into my existing tank
bungs. The close nipple on the top threads into existing tank bung. The other end of the 3/8 sticks out of tank allowing
the hookups.
These are now my pickups and it allows me to still utilize the tank bungs ( no tank modifications) and 1\32 under a 1/2 inch pickup.
Hope this helps
Gerry
KNOT-RIGHT is offline
Old 06-18-2005 | 07:15 AM
Crazyhorse's Avatar
you may have dual pickups in your tank. if so, plumb them together and run 1/2 line from them.
Crazyhorse is offline
Old 06-18-2005 | 11:03 AM
I am re-installing my motor after upgrading it further this year,if i cannot get enough fuel thru my pickup then i am going to pull fuel tk sending unit and build a 1/2 inch pickup thru it on bench then re-install it,use original 3/8 pickup for return fitting as i am returning fuel to suction side of pump and would prefer to return it to tk,just isn't possible without doing something like i described,Smitty
Old 06-18-2005 | 06:35 PM
KNOT-RIGHT's Avatar
I ran my returns back to the fuel filler tube. Cp performance
sells a fitting for this. I tigged stainless nipples to my filler neck after I saw the fitting they sell.
Another trick I did was measure the amount of fuel feeding
each motor by starting the engine with fuel feeds on one engine in a gallon container. ( Carb Blown Setup). Filled the gallon in 9 seconds.
I run #10 feeds with #8 returns.
Fuel Setup is critical on Blower setups!
Make sure you have enough delivery.
Gerry
Old 06-18-2005 | 11:32 PM
RedDog382's Avatar
Take your engine builder's advice.
If you nice new motors don't get enough fuel and lean out, you'll destroy them real fast!
What warranty? He told you so ...
RedDog382 is offline
Old 06-22-2005 | 06:26 AM
First I'd like to thank articfriends and caveman for all there help, both have been very helpful. Now back to fuel. Since we have possibly figured out what to do with these 1/2" fuel lines, another problem arises. My motor builder wants to put on gas / water separators. I can't find any one who sells them with 1/2" lines, the biggest gas ones I can find are 3/8" they make them bigger for diesel but not for gas. Is there anyone who sells them with 1/2" inlets for gas or can I use the diesel filters.
Old 06-22-2005 | 07:15 AM
Both Jegs and Summit Racing (online and catalog) sell Perma Cool water seperating filters which have 1/2" fittings.
gossip is offline
Old 06-22-2005 | 07:41 AM
KNOT-RIGHT's Avatar
Vinnie, This is similar to what I used
http://store.summitracing.com/defaul....asp&x=24&y=16
Or if you want the cats ASS
http://www.cpperformance.com/detail.aspx?ID=258
The first one will work fine.
Gerry
PS. We have a good size rafting party going on at
Block Island new harbor for the fourth of july.
Arrive on 7-2 leave monday 7-4. Email me for details.
Come on down! Its a good time!
