How the heck do you run motors on hose when it sucks the hose and collapses it?? >
Old 06-19-2005 | 11:57 AM
NJgr8ful's Avatar
Question How the heck do you run motors on hose when it sucks the hose and collapses it??
When I try and run my motors to flush each time in the friggen hose collapses down to a flat pancake?!?! I am very afraid to run like this. Is there any remedy that other folks have figured out?? A 'SUPER' hose or??? I bought the 'best' most expensive hose at the garden center and still sucks it dry ... HELP! TIA
NJgr8ful is offline
Old 06-19-2005 | 12:55 PM
puder's Avatar
speel chekk this fokker!
Default Re: How the heck do you run motors on hose when it sucks the hose and collapses it??
you could use the garden hose and fill up a large bucket (small garbage can perhaps). run a smaller hose from yoru engine into the can (water reservoir) and kepethe supply hose running, it should suck eth water from eth can while the hose keep steh supply sufficient. Thats how i usually winterize my boat, except i kill the water supply and dump anti freeze into eth bucket when the water level get super low.
Pardon me, while I whip this out!
puder is offline
Old 06-19-2005 | 05:17 PM
you must have one of those super charged water pumps
im with puder try to find a large drum the out drive will fit in
those fish buckets fishermen use to sort their fish should work
nicely
ripley is offline
Old 06-19-2005 | 05:56 PM
CMG's Avatar
CMG
maybe its the 5500 rpms ??????
Chris G.
CMG is offline
Old 06-19-2005 | 07:04 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Run A Hose From 2 Seperate Hose Out Lets Into A Y And Into A 3/4 Id Full Flow Hose And You Can Run To Approx 15-1800 Rpm. If Your On A Well It will Not Work You Must Be On City Water.
WILDTHING TAZ is offline
Old 06-19-2005 | 08:05 PM
CMG's Avatar
CMG
I'm on a well and have plenty of pressure, never a problem.
Chris G.
CMG is offline
Old 06-19-2005 | 08:48 PM
Sean H's Avatar
A to Z
use the bucket method, works pretty well....
Sean H is offline
Old 06-19-2005 | 10:05 PM
NJgr8ful's Avatar
Thanks for all replies ... but I have #3s SSMs and don't pull water thru the drives
NJgr8ful is offline
Old 06-20-2005 | 06:14 AM
LFT
The real issue is your seawater pump is capable of drawing the water at a higher rate than what your well is capable of delivering. It's not about pressure it's about the volume.
Try removing the lid off of your sea strainer and put the hose into the basket let it fill up before you start the engine. This should allow you to run the motor at idle without running the pump dry.
A 5/8" water hose is only able to flow at best between 7-10 gpm (gallons per minute) and a good single stage seawater pump draws between 15-18 GPM at idle. this is why you are collapsing your hose.
Be sure to keep an eye on your exhaust water while running your engine this way to ensure that you are getting enough water through your system.
LFT (Louisiana Freight Train)
LFT is offline
Old 06-20-2005 | 08:01 AM
NJgr8ful's Avatar
LFT thanks for reply I have no sea strainers and I don't use well water ... Have city piped water Volume is certainly the issue ...
NJgr8ful is offline
