NAVMAN Fuel FLow Meters???? >
Old 06-20-2005 | 11:34 AM
dkwestern's Avatar
Default NAVMAN Fuel FLow Meters????
Anyone installed the NAVMAN fuel flow meters, and hooked them up to the GPS? I am thinking about doing this setup but wanted some opinions.
Also The setup may be an issue. I have 2 gas tanks, which 1.flow through the fuel filter,
2. then through electric pumps,
3. then into a 5 gallon "dump tank"
4. Then 3 lines come out, and go to 3 engines
5. and 3 return lines will dump back into the 5 gal "dump tank"
IF I put one sensor between each filter and pump, I should not have to worry about the return lines correct.
The return lines never go back to the main tanks, so whatever the meter says should be accurate right??
Thanks for any help and experience with Fuel flow meters.
dkwestern is offline
Old 06-20-2005 | 12:12 PM
Stormrider's Avatar
JC Performance Engines
Default Re: NAVMAN Fuel FLow Meters????
If you do decide to get one...
I have one I never installed, and can't use w/ 500+hp.
Stormrider is offline
Old 06-20-2005 | 12:39 PM
glassdave's Avatar
Neno the mind boggler
i have them on my boat and they work great. where ever you put it make sure there is a filter before the sender. i had to mount mine before the factory seperator/filter so i had to put an in line filter just before the sender. also mount them vertically if you can.
08 OPA High Points Champion
glassdave is offline
Old 06-20-2005 | 12:48 PM
Scott's Avatar
Charter Member #30
I wanted to run them with my Navman but the 500HP thing scared me away. I will not lean out a engine just to have another gadget
I have Steps & Bubbles!
Scott is offline
Old 06-21-2005 | 09:40 AM
dkwestern's Avatar
Thanks guys.
Glassdave, was there a simple single wire from each meter that connects to the gps? And is it just a power, ground, and whatever runs to the GPS hookup? Also is it just an "inline" barbed style installation, where I can cut a fuel line in half and put it in with clamps? Thanks, Darren
Stormrider, I'll need the twin engine style, is that what you have?
CAPTAIN CHUCK
0
05-25-2007 09:19 AM
waterman
04-02-2006 11:52 PM
Shah Mat
05-05-2005 07:12 PM
Strip Poker 388
11
03-22-2005 12:30 AM
Hy-Velocity
15
12-17-2004 11:17 AM
