Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
fixin tailrot,who is right >
Old 06-21-2005 | 06:12 PM
Default fixin tailrot,who is right
i have a 26ft searay that has a rotten transom &stringers
starboard side is rotten thru out port side is not as bad
the stingers are rotten up to the gas tank which i about 5ft
from the stern i know it is rotten further up thats far as i
can go without pulling the gas tank
i have had two so called glass guys come out here to look
at my delemma
one wants to cut out the ass end of the boat redo the gel
coat (how is he going to match the color?)
& rip out the stringers which are probley ate up clear into the cabin MASSIVE AMOUNT OF WORK
THE OTHER SAYS YOU DON'T MESS WITH THE FORM OF
THE BOAT ,YOU CUT IT OUT FROM THE INSIDE &THE STRINGERS DON'T HAVE TO BE REPLACED ALL THE WAY UP
JUST IN THE ENGINE CONPARTMENT
SEE MORE HISTORY IN THREAD (WHY AM I BLOWING CLUTCHES)
WHO DO I BELEIVE IN EC
THANKS IN ADVANCE FOR ALL REPLIES
Attached Thumbnails fixin tailrot,who is right-mvc-002f.jpg   fixin tailrot,who is right-mvc-001s.jpg   fixin tailrot,who is right-mvc-011f.jpg
ripley is offline
Old 06-21-2005 | 09:13 PM
glassdave's Avatar
Neno the mind boggler
Default Re: fixin tailrot,who is right
the transom should be done from inside. unfortunately a rule of thumb is you only see about half of the damage, the rest will show its self once you get into it. as long as the stringers are good from the first bulkhead forward you can replace them in the engine compartment alone but it should be done by someone experienced with this type of repair. transom and stringer replacement is a very large undertaking any way you look at it.
08 OPA High Points Champion
glassdave is offline
Old 06-22-2005 | 05:24 AM
i have a feeling it goes farther than the first bulkheads
what about the starborard & port bulkheads in the engine
compartment
also have you heard of any good glass guys in the elizabeth city nc area i really working towards getting this done as fast as i can,
thanks for responding
ripley is offline
Old 06-22-2005 | 08:59 AM
glassdave's Avatar
sounds like a pretty big project. if you try and repair the stringers in just the engine compartment you could have a potential problem at that joint where the badstringers are on the other side of the bulkhead. the running surface will want to flex and could cause a faliure right there.
sorry but i dont know any glass guys in that area. wish i could help more. do you have any larger pics of the engine compartment? just wondering about bulkhead placement on that boat.
i think Fred (Too Old) of TRick Marine is in NC. contact him and i'm sure he will know someone what with all the project boats he has had
also have you though of takeling this project yourself? there is alot of good info and knowlegable people on this site to help you through it.
Old 06-22-2005 | 09:07 AM
i ll get some pics to you this evening i really want this done right ,
once i get it gutted (all rigging out of the way )& see what kind
of work i truely looking at, i may deside to go that rought
thanks again for responding
ripley is offline
Old 06-22-2005 | 06:05 PM
hello glassdave
here is the pics that hole on th starboard side by th first bulkhead is basicly hollow let me know what you think
thanks for lookin
Attached Thumbnails fixin tailrot,who is right-mvc-005f.jpg   fixin tailrot,who is right-mvc-004f.jpg   fixin tailrot,who is right-mvc-003f.jpg
ripley is offline
Old 06-23-2005 | 11:37 AM
glassdave's Avatar
do you have access to the stringers at the front of that forward bulkhead or do you have to cut the floor? it looks like the stringer and engine mount are glassed togather. are they both rotted out inside?
Old 06-23-2005 | 01:18 PM
yes they are the starboard is the worst that bulkhead supports
the gas tank & i have a feeling its filled w/ foam ,infront of that
is a berth which is damp on the starboard side , that is also
where the stepdown pump is
as i dig more out i'll send you some more pics
any more sugestions at this time
thanks
ripley is offline
Old 06-26-2005 | 07:35 PM
more pics ,pulled the gas tank & the base is soft for that, right in front of the tank base is the master berth where a step-down pump is stringers are soft at the bottom
any suggestions?
Attached Thumbnails fixin tailrot,who is right-mvc-016f.jpg   fixin tailrot,who is right-mvc-015f.jpg   fixin tailrot,who is right-mvc-014f.jpg
ripley is offline
Old 06-28-2005 | 03:40 PM
PatriYacht's Avatar
There is a product called Seacast that is a pourable resin/fiberglass mix that you could use for the stringers. Cut the top off the stringers, clean out the rotted wood and pour this stuff in. Then cap the stringers with a layer of fiberglass. Their website says that Callen Marine used Seacast for the transom of their twin turbine 55 footer because wood flexed too much.
PatriYacht is offline
