30' outboard set ups
Not 30' but running a 28 Skater 300 promax's 20" mids with Sportmaster lowers, 1.62 gears turning 15x34. The prop shaft is 1 3/4" above the bottom of the lowest part of the boat.
They are the older promax's. So far the only lower unit problems have been prop shaft seals. I check the lowers just about everytime I take the boat out so no major issues yet. How much water pressure are you running?
14.5x30s turning out. Sportmaster lowers and 1.87:1 gears. 2.5efi 260s and 96.2gps @ 7800 last weekend. I am still learning to drive her, so that 3.8 mpg is a reasonable goal.
Has anyone tried spinning their props IN on a 30? I thought of doing it, but it isn't how I would run the boat from day to day.
Haven't measured the x-dim, yet, but the boat was dialed in at Lake-X. I doubt I can teach those guys anything about setup.
What does that boat weigh? You are turning some big wheels and some big gears.
Originally Posted by X-Rated30
DANG!
DANG!
1998 30 spectre 300x's 20" sportsmaster's, 15x32 3 blades...6450 rpms at WOT, myself, 1 passenger, 13 lb dog, approx 80-100 gals of fuel 10-15 mph tailwide 1 1/2 chop...best ever of 105.5 on a garmin 182 c. havent been able to hit it again..its a consistent 100 mph ride
