Valve covers for 454 with Roller Lifters >
Old 06-24-2005 | 09:38 AM
QUIKDECISION's Avatar
Default Valve covers for 454 with Roller Lifters
Does anybody have a reasonably priced set of (4) valve covers to fit a BBC with rollers? Or does anybody have source
for valve covers? This twin motor rebuild is killing me.
Thanks...
QUIKDECISION is offline
Old 06-24-2005 | 09:44 AM
Stormrider's Avatar
JC Performance Engines
Default Re: Valve covers for 454 with Roller Lifters
Trick Marine.
Stormrider is offline
Old 06-24-2005 | 10:00 AM
You may also you valve cover spacers. Those would be available from Trick Marine also. We make them. 1.150" extra clearance.
Chris
cstraub is offline
Old 06-24-2005 | 10:45 AM
articfriends's Avatar
You can run crane gold and comp cams pro-magnum roller rockers with stock valve covers by grinding oil dripper tabs off inside s valve covers and sandwhiching a set of felpro rubber valve cover gskts that have the steel shim in the gskt. I have done this,the aftermarket valve covers i bought from cp performance wouldn't clear the procharger on my motor. I ran a bead of high quality black rtv on top of stock o-ring in vcover (between the gskt and valve cover) and use slightly longer bolts. Ive done this with stock heads,merlin heads and afr heads,it doesn't leak,and even though it sounds cobbled when you look at motor you can't even tell its been done,good luck,Smitty
articfriends is offline
Old 06-24-2005 | 08:53 PM
I thank you all for your responses.
I believe that I will first look into the spacers that
trick marine has.. I have a set of cast valve covers that
came off a late model 454 truck, they're pretty decent, but
of course, just not tall enough.
Old 06-24-2005 | 10:08 PM
Payton's Avatar
Charter Member #927
I bought 2 sets off ebay a year ago. They are polished aluminun w/flames etched in the cover. They are not the tall ones. they look very cool and clear my Crane Gold rockers. I use the cork gasket with steel in the middle. I think it's Felpro.
Payton is offline
Big Block Billy
7
10-26-2008 04:26 PM
Ken N
1
10-05-2008 11:17 AM
traviss
14
09-16-2002 06:12 PM
Bo Knows
04-02-2002 09:20 AM
