high oil pressure >
high oil pressure
high oil pressure
Old 06-25-2005 | 08:27 AM
Default high oil pressure
I have high oil pressure in my 1989 350 mag now I know its an old motor with alot of hours so what should I check it runs at 75lbs when idling but then drops to about 40lbs when running...what should I check? I have a remote oil filter if that matters I am running 20 50 oil thanks
Harry
tahoeguy318 is offline
Old 06-25-2005 | 02:51 PM
Default Re: high oil pressure
Is this a new problem.
I had the same thing happening with my oil psi and the engine had the wrong sensor on it. It was working in reverse.
Griff is offline
Old 06-25-2005 | 05:25 PM
RedDog382's Avatar
Mechanical guage to see if readings are accurate.
RedDog382 is offline
BDiggity
7
07-07-2008 05:57 PM
formula18
2
06-28-2006 11:28 AM
fastlane40
9
09-16-2004 03:21 PM
FlyFast
13
05-10-2004 11:39 PM
dloftis
Baja
3
04-23-2002 05:01 PM
