What oil presure on your 454 Mag EFI? >
Old 06-25-2005 | 09:30 PM
speed demon's Avatar
Default What oil presure on your 454 Mag EFI?
I am wondering what oil pressure other 454 Mag EFI 385hp owners are seeing on their engines. Mine is 40 - 41 at anything above idle and 20 at idle 600 rpm. The manual says at 2000 rpm and above 30 - 70 is normal and not less than 4 at idle. I am just wondering if my numbers are normal or on the low side compared to others. Thanks!
speed demon is offline
Old 06-25-2005 | 09:44 PM
Vinny P's Avatar
I hate the winter!!
Default Re: What oil presure on your 454 Mag EFI?
When I had my 454 Mag MPI motor, I had just about the same pressures you are seeing. I would say that you are fine.
Vinny P is offline
Old 06-26-2005 | 08:50 AM
Payton's Avatar
Charter Member #927
I am 60 psi when running and 25 at idle, right after a hard run. After it cools back down will idle at 40psi.
Payton is offline
Old 06-26-2005 | 09:17 AM
mopower's Avatar
Toxic FORMULA
My stock 454s were about the same as Paytons. Your's don't sound out of the ordinary
mopower is offline
Old 06-26-2005 | 06:56 PM
Poorsche's Avatar
Got MarinePower 454 efi's--seeing same numbners as evberyone else. I'm using Castrol Dino/Synthetic Blend oil.
Poorsche is offline
Old 06-26-2005 | 07:08 PM
Dave M's Avatar
Veteran: Navy
I had 40-45 above idle, 20 at idle.
Dave M is offline
Elite Marine
Pantera
3
10-06-2004 09:05 AM
blown formula
31
06-10-2003 06:59 PM
Checkmate283
08-30-2002 09:35 AM
checkmate981
Checkmate
1
05-06-2002 11:25 PM
checkmate981
4
02-02-2002 01:45 AM
