changeing trim indicater on bravo 1 >
Old 06-28-2005 | 09:11 AM
Rrice's Avatar
Angry changeing trim indicater on bravo 1
any tricks to changing the trim indicaters and wiring on a bravo 1 with the drive on?
Rrice is offline
Old 06-28-2005 | 09:36 AM
Default Re: changeing trim indicater on bravo 1
Do a search. This topic has been covered several times. You will find I accomplished it without removing the gimble ring.
1BIGJIM is offline
Old 06-28-2005 | 09:12 PM
To remove the grommet/hold down: Steer drive hard right, trimmed fully down. You should be able to just get a 1/4" drive extension between the bellhousing and the gimbal ring. Attach a swivel 7/16" socket after the extension is through the gap. Now you can remove the screw and plate. Note, if the drive isn't quite down far enough, you may have to pull the rear trim pin to let the drive down a bit more.
When you pull the wires through, tie a wire or string to the end from in the boat to pull back the new wires.
Not too bad, but I think they could have left a little more room between the gimbal ring and bellhousing. It's a bit tricky reinstalling the hold down plate and screw for the grommet.
Good luck!
Falcon is offline
Old 06-28-2005 | 09:21 PM
Outdrive1's Avatar
Masher touches my
Good luck!
Can you post a picture of what you are talking about. I know my indicator is a little off and I was thinking of replacing it too...
Outdrive1 is offline
Wally
41
06-29-2022 11:39 AM
jryan26
Fountain
2
05-24-2007 09:33 AM
big poppa pump
1
04-30-2003 10:03 PM
Mr.Gov'nt
Nordic
1
01-08-2003 08:00 AM
Gassticks
8
06-04-2002 08:15 AM
