CMI tailpipes need to be changed, any sujestions >
Old 06-28-2005 | 09:24 AM
magnum27's Avatar
Default CMI tailpipes need to be changed, any sujestions
I have a set of CMI dry pipes that need to be reconfigured for my boat. The person I got the from had the flanges that connect to the header cut and turned 180 degrees so that they where to go over the transom. I need them switched back. Also will need them lengthened three or four inches because they barely exit the transom. Probably need a angle put in them also so they will go straight out the back and not angled 45 degrees to the waterline. Who should I get in touch with to do this work in a timely manner as time is of the essence. (Of coarse it always is)
magnum27 is offline
INDY27
1
02-24-2006 11:14 PM
Shah Mat
Checkmate
7
07-10-2004 04:54 PM
waterbum
13
02-27-2004 09:20 AM
puder
02-21-2002 09:36 AM
