Q-Jet vs Holley >
Q-Jet vs Holley
Q-Jet vs Holley
Old 06-29-2005 | 09:10 AM
Default Q-Jet vs Holley
Is there any benefit to using a square bore carb vs a spread bore. It would seem in theory at least that the square bore carb would give a more balanced charge especially considering the frequent wide open throttle position when used in boats. In automotive applications the Q-Jet shines for a variety of reasons but what about marine when economy is not the priority?
LiberatorII is offline
Old 06-29-2005 | 10:31 AM
Wobble's Avatar
SORE MEMBER
Default Re: Q-Jet vs Holley
Main reasom I can see is that you have a larger selection of intake manifolds to choose from. Both are good carbs in their own right. Also there are very few aftermarket marinized spreadbore carbs to choose from.
Wobble is offline
Old 06-29-2005 | 01:40 PM
Personally I'd pick a Demon
In all seriousness just changing a carburetor is not going to net you much in a marine application. Given the amount of HP it takes to make a noticeable speed difference. That being said if you're building, or modifying a performance engine then using a modular style carburetor that can be more precisely tuned would be recommended.
RumRunner is offline
Old 06-29-2005 | 03:54 PM
The Holley (demon etc), do have the advantage of dual fuel bowls. A Q-jet with the one bowl could technically get sucked dry if your fuel system wasn't up to snuff. Otherwise, you prob wouldn't notice a power gain...
I'm a Q-jet fan myself, but they make more sense on cars....
Madmax is offline
RickR
1
01-17-2004 06:49 AM
BAD-HABIT
13
09-05-2003 09:13 AM
DonMan
4
07-10-2003 07:48 PM
