30' o/b bet -- need help
Old 06-29-2005 | 09:14 PM
X-Rated30's Avatar
Default 30' o/b bet -- need help
I have a friend that knows alot about outboards, but not large boats. I know a little about large boats, but nothing about outboards. We have a bet we are going to let OSO settle.
The boat is mine -- 30 foot Spectre, 4400#, 1.87:1 gears, and 14.5x30 3-blade cleavers running on pump gas.
Which would be faster on the top end, a pair of:
2.5efi 260s
or
300 Drag motors?
I'll tell you my opinion after I get enough results to say I won.
X-Rated30 is offline
Old 06-29-2005 | 09:25 PM
apache21's Avatar
Default Re: 30' o/b bet -- need help
The 260's will only get that spectre to 105mph the 300 drags with the right props will get you somewhere in the 110-111.
apache21 is offline
Old 06-29-2005 | 10:06 PM
The drag motors easy. But I bet you will not get many rides with those motors. 280 os or 300x would be the power of choice
Just my opinion
mmwalters is offline
Old 06-29-2005 | 10:13 PM
Sean H's Avatar
A to Z
i say drag motors would be faster, bet i would also take a set of 300x's.... easy to maintain and shift....
Sean H is offline
Old 06-30-2005 | 06:56 AM
berns29scarab's Avatar
the drag motor's ...love my x's
berns29scarab is offline
Old 06-30-2005 | 09:37 AM
Stock vs. Stock, the drag motors have more HP so they will be faster! It's not rocket sience...or is it
Sneaky Fast is offline
Old 06-30-2005 | 11:43 AM
dreamboater's Avatar
Drag motors easy. If the race was more than 50 hrs , the 260's would win
dreamboater is offline
Old 07-01-2005 | 07:49 AM
X-Rated30's Avatar
Real cut to the chase question: can the 300 Drag make top end power on pump gas?
Old 07-01-2005 | 07:52 AM
dkwestern's Avatar
Probably not for long.
dkwestern is offline
Old 07-01-2005 | 08:05 AM
You can change the heads to run 93 octane. The real advantage the drag motor has is the SVS intake and spinning the motor 9500 to even 10k + in drag applications. The 280 ROS is by far a better motor for your boat if you want to stay with the 2.5 block. The 300x would be number 1 choice if you put a lot of hours on the boat.
ROADHOG
08-27-2006 02:40 PM
kennyo
26
08-11-2005 07:38 AM
Spectre Man
04-12-2004 12:25 PM
Fightclub
03-27-2004 08:22 AM
