what cylinder should i install my pyrometers in >
Old 07-04-2005 | 02:42 PM
ratman's Avatar
Default what cylinder should i install my pyrometers in
what cylinder should i install my pyrometers in on bbc 577 n/a's?
what temp should i be running wfo ? thx, in advance. ratman
ratman is offline
Old 07-04-2005 | 04:40 PM
articfriends's Avatar
Default Re: what cylinder should i install my pyrometers in
I had gaffrigs in mine lightning headers in # 7&#8 but the sucked because they read 1500plus degrees all the time when on plane,I added more fuel to get them down to 1250degrees and boat ran like a turd,fouled plugs etc,Smitty
articfriends is offline
Old 07-04-2005 | 08:31 PM
ratman's Avatar
i have one for each engine...whitch hole tends to run hottest on bbc? thx in advance, ratman
ratman is offline
Old 07-05-2005 | 08:42 AM
ratman's Avatar
ttt
ratman is offline
Old 07-05-2005 | 02:04 PM
KNOT-RIGHT's Avatar
I would use them as a guide only.
type of Intake plays a roll aswell as N/A or forced induction.
N/A Cyl 7 would be the leaner.
However if you are gonna reuse this exhaust for roots
supercharging you may take that into consideration.
Flip a roots supercharger and see it feeds the back cylinders first which would make the front cylinders lean. The
way the carbs sit on top of the roots also plays a roll on it
I would not go over 1350F
My front cylinders run the leanest
# 2 # 7 would be the choice
remember the lower the CR the higher the EGTs
the higher the CR the lower the EGTs
the leaner A/F Ratio the higher EGTs
the richer A/F Ratio the lower EGTs
Hope this helps
Oh put the thermo couple as close to the head as possible
READ THE PLUGS!
Gerry
KNOT-RIGHT is offline
Old 07-05-2005 | 02:07 PM
JCPERF's Avatar
I would dyno the engines and find out your hottest cylinders.
JCPERF is offline
Old 07-05-2005 | 02:19 PM
Wobble's Avatar
SORE MEMBER
#2 on a merc dual plane intake motor, on any other type intake it could be any. My dyno results with port matched merlin single plane gave very even egt's. BUT that was with dyno headers.
Wobble is offline
Old 07-05-2005 | 02:43 PM
KNOT-RIGHT's Avatar
JCPERF You should put one in your Avitar it looks pretty hot.
Well over 1500F
Old 07-05-2005 | 06:27 PM
JCPERF's Avatar
Well over 1500F
JCPERF is offline
Old 07-05-2005 | 06:32 PM
carney's Avatar
I ran them in 5 and or 7
carney is offline
