Carb Leak 93' 454 MAG >
Old 07-04-2005 | 07:51 PM
Default Carb Leak 93' 454 MAG
I have a baja 32 force with 93' 454 mags. I belive the carbs are Holly. They have a primer on the front of the carbs but whenever i give throttle or pump the throttles to start it leaks out the botom where the primer goes up and down. I didn't know what i needed, if it is just a seal on the primer or if they make some kind of kit to repair the entire assembly. If anybody has had this problem or if you know where i can get the parts i need it would be appreciated. Thanks for anything.
Mike L is offline
Old 07-05-2005 | 08:39 AM
Default Re: Carb Leak 93' 454 MAG
If that is a holley carb, the object your calling a primer is an accelarator pump. There are two sizes 28cc and 50cc. Go to any speed shop or good automotive store and get one. There very easy to replace. Its an easy fix and wont cost you but a couple bucks.
scarrab30 is offline
Old 07-05-2005 | 11:19 AM
If the carbs are stock Merc, they are Weber carbs.
Griff is offline
Old 07-05-2005 | 01:24 PM
I am sure it said Holy on the carb but i will check tonight. How do I know what size accelerator pump the carb has? Thanks for all the help, its appreciated!
Mike L is offline
Old 07-05-2005 | 05:52 PM
blue thunder's Avatar
If they are holley accel pumps the 50cc will be about twice as deep as the 30cc diaphram. If you take the diaphram with you to the parts store you will easily see which one you need.
BT
blue thunder is offline
Old 07-05-2005 | 09:08 PM
Got the diaphram out. thats were it wa sleaking. Thanks for the help. I also cannot find any numbers on the carb that tell me what size it is. I have alot of part numbers but i was looking for like 550 or 850 cfm
Mike L is offline
stinger390
5
11-11-2007 03:42 PM
Shore Thing
16
11-10-2006 03:42 AM
born2burn
1
09-22-2004 11:38 PM
Preuni
14
01-08-2004 09:28 AM
Fast Forward
10
05-22-2003 07:45 PM
