Need info on 92 Chevrolet 5.7L Truck engine
Trying to replace a worn-out cheap header system with the factory manifolds....I am getting different answers on weather the engine uses Exhaust Manifold Gaskets or Not......3 different dealers/parts dept say no......But Alldata says yes but no part#......This is on a 1992 Chevrolet K2500 with the 5.7L.......
Randy
Randy
Might try hitting the boad here;
http://www.coloradok5.com/
No Gaskest Required,Just Make Sure The Surfaces Are Flat And Clean,have Manifolds Checked If They Are Used.they Are Designed As A Machine Finish Will Not Leak,gaskets Will Blow Out After Sometime.I Have Done This 100s Of Times With No Problems!TORQUE FROM INSIDE OUT!
boot
08-06-2002 01:08 PM
