Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
fix chips on bottom of boat???? >
Old 07-05-2005 | 07:47 PM
gsmith9898's Avatar
Default fix chips on bottom of boat????
I got a couple of chips on the bottom edge of my boat. It is about a inch long and shows black undernieth. What is a easy way to fix this, so it doesn't stand out?
gsmith9898 is offline
Old 07-06-2005 | 07:09 PM
H2Xmark's Avatar
Default Re: fix chips on bottom of boat????
sand the area with some 60 grit, hit it with some acetone to clean then buy some Gel paste from west marine or a Blue water store, you can tint the paste with coloring agent to match the rest of your gel, you wont get a perfect match put it will be close, follow mixing instructions on can of paste, apply to area this stuff will shrink a little so add a little extra then cover with the acetate paper[clear plastic sheet] and tape to seal out air,
H2Xmark is offline
Old 07-06-2005 | 10:05 PM
gsmith9898's Avatar
why do you cover it when done ?
Old 07-07-2005 | 06:18 PM
glassdave's Avatar
Neno the mind boggler
gel coat wont cure in the properly presence of air. it needs to be sealed off. in the industry we either use a waxing agent or spray a few coats of PVA (polly vinyl alchohol) on it .
08 OPA High Points Champion
glassdave is offline
baddogz28
Fountain
14
01-16-2008 12:37 PM
powerquest 380
25
05-21-2007 02:01 PM
Zanie
4
05-10-2005 12:33 AM
26sonic
01-20-2003 10:22 AM
