Bravo vs. Bravo HP transom assembly >
Old 07-08-2005 | 10:27 PM
Scarab28's Avatar
Default Bravo vs. Bravo HP transom assembly
What exactly are ther differences between a Bravo HP transom assembly versus a stock bravo 1 transom assembly. What changes are required to retrofit a bravo HP transom assembly to an older Bravo 1 drive.
Scarab28 is offline
Old 07-09-2005 | 07:08 AM
Turbojack's Avatar
Default Re: Bravo vs. Bravo HP transom assembly
HP has stronger hinge pins. You will not have trim gauge or trim limit, have to use mech. trim gauge.
You are wanting to go from HP to standard? I think there should not be any problems changing except for trim gauge & limit.
Turbojack is offline
Old 07-09-2005 | 10:43 AM
Not true anymore about the trim gauge or limit. It now includes the same trim sender and adapter included with the ITS.
Falcon is offline
Old 07-09-2005 | 10:44 AM
I have to correct my statement: It's "available" with the sender. They also sell it without.
Falcon is offline
Old 07-09-2005 | 12:04 PM
Scarab28's Avatar
Thanks - I want to go from a standard to an HP so it sounds like the only issue I'll have is the trim sending units. Sound correct?
Scarab28 is offline
Old 07-09-2005 | 03:53 PM
That should be the only difference. Some dealers may not be aware that the HP is now available with the trim sender. You can add it to the later ones because the mounting points are there but you have to purchase all of the individual parts. It's much easier to order it the correct way.
Falcon is offline
thedonz
Swap Shop
1
10-29-2008 09:41 AM
wrasse
05-28-2007 09:05 AM
offthefront
2
05-06-2006 04:46 AM
convincor
4
02-10-2003 08:42 AM
