Coupler change in 25 Outlaw - any hints? >
Old 07-11-2005 | 01:51 PM
Formula311-SR1's Avatar
Default Coupler change in 25 Outlaw - any hints?
Have to help a friend put a coupler in a 2000 Baja 25 Outlaw with a 415 EFI motor. Any hints to make it easier? What is required to re-align the motor? Tools etc.
We have use of a good lift for getting the motor out.
Should he buy the steel coupler or the aluminum? Stock power and where we boat the boat doesn't come out of the water much if at all.
Formula311-SR1 is offline
Old 07-11-2005 | 02:16 PM
RLW
Default Re: Coupler change in 25 Outlaw - any hints?
You are going to need a Mercury Alignment Tool.
RLW is offline
Old 07-11-2005 | 02:50 PM
Thanks RLW
How hard is it to align the motor if we got the tool?
Old 07-11-2005 | 04:49 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You need the tool, should not be an 'if' choice.
Assuming stock Merc stud motor mounts, check that the lower adjusting nut has not backed down before doing any removal work. If it has, then raise the lower nut back up until the mount is tight against the upper lock nut 1st, THEN remove the upper nut, allowing the motor to come out, leaving the lower nut alone. Reason being the top nut won't move making for an out of alignment issue like the lower nuts are very prone to doing. By riasing the motor back up to the originaal position, assuming it was aligned correctly at one time, you will be very close on alignment when reinstalling saving some headaches.
ALignment is really easy, just think about the grease marks on the tool when checking. Wiped off on the top= lower the front of motor.
Alum couple is plenty, Would rather wear the aluminum splines vs putting extreme pressure on the gimble, bearing, input shaft............
Why does it need replaced already? Motor mounts back off? Double check that 1st
US1 Fountain is offline
Old 07-11-2005 | 05:00 PM
Good advice.
That's the way I've done it in the past.
The only thing I can really add is, make shure
the fiber washer and the spring "gizmo" on the rear
mounts stay in place, once you drop the engine back in.
JaayTeee is offline
Old 07-11-2005 | 09:34 PM
outdrive man's Avatar
the gizmo is called a wave washer
outdrive man is offline
Old 07-11-2005 | 09:49 PM
You should put a hose clamp around the locking washers/tabs that hold the bottom adjusting nut on the front engine mounts.
aquaman is offline
Old 07-12-2005 | 08:25 AM
Thanks for the excellent info.
US1 - the "if" should have read if we get the tool and align it ourselves or whether we have someone align it.
Old 07-13-2005 | 12:12 AM
Ginger or Mary Ann?
I have no idea on the charge to have it checked and adjusted if needed, but I'm assuming you could buy the tool for less, and then have it forever. I pull my drives every spring for greasing and alignment checking.
Old 07-13-2005 | 08:53 AM
Good point!
Sounds like a good tool to have regardless.
