V-6 Vibration - What can it be? >
Old 07-11-2005 | 02:02 PM
GNJ's Avatar
GNJ
Question V-6 Vibration - What can it be?
I have a 96 4.3 liter vortec V-6 that was just rebuilt and installed. New 0.030 over hypereutectic pistons and ground the crank 0.010. A local machine shop balanced the assembly as well and then I installed the components in the block and then into the boat.
There is a strange engine vibration above 2,000 rpm that was not there before and does not seem right at all.
What I am curious to know, is if the balance shaft has to be in a particulair position when assembling the motor? Anybody know or help?
GNJ is offline
Old 07-12-2005 | 09:34 AM
GNJ's Avatar
GNJ
Default Re: V-6 Vibration - What can it be?
Anybody????
GNJ is offline
Old 07-12-2005 | 10:31 AM
Dave_N's Avatar
Check out this thread, could be a similar issue.
http://www.offshoreonly.com/forums/s...d.php?t=105864
Dave
Dave_N is offline
Old 07-12-2005 | 10:35 AM
Wobble's Avatar
SORE MEMBER
The balance shaft does have to be timed I beleive. On the one balance shaft motor I worked on it had a dot on the gear that had to line up at same time as cam and crank. It wasn't a chevy v-6 though.
Wobble is offline
Old 07-12-2005 | 10:39 PM
GNJ's Avatar
GNJ
Thanks Wobble - I will try to get a chevy motor service manual to get more details.
Gary
GNJ is offline
Old 07-12-2005 | 10:44 PM
FOUNTAINATLAST's Avatar
The balance shaft as suggested was the first thing that came to mind, how about motor alignment and ujoints on the drive???
FOUNTAINATLAST is offline
Old 07-13-2005 | 07:44 AM
GNJ's Avatar
GNJ
Fountainatlast: The factory mounts and settings were not not disturbed. I think alignment is not the culprit. I beleive the U-joints are ok as well. Good questions though.
When I put it together, I did look to see if there was a mark on the balance shaft gear to align but did not find one. Without seeing a mark, I ignored it after that and put it together in "whatever" position.
If in deed this must be in a certain position, then it could be where the vibration is coming from. Will have to read up on this.
GNJ is offline
riverdude
14
11-22-2005 07:51 PM
boatfreak
2
06-27-2005 07:30 AM
Team Reyco
6
09-15-2004 05:58 AM
Shah Mat
4
04-22-2003 03:37 PM
max
5
11-12-2002 08:24 AM
