Reverse Rotation Crank- Difference? >
Old 07-13-2005 | 01:18 PM
BOOSTEDSCARAB's Avatar
Default Reverse Rotation Crank- Difference?
Does anyone know the differences between a standard rotation crank and a reverse rotation crank?
I'm building up 2 350's stroked to 408's and need some info.
Thanks all!
BOOSTEDSCARAB is offline
Old 07-16-2005 | 01:03 PM
Strip Poker 388's Avatar
Rob
Default Re: Reverse Rotation Crank- Difference?
I belive the crank is the same ?The differance is in the cam shaft with firing order.
Rob
Strip Poker 388 is offline
Old 07-16-2005 | 01:33 PM
KNOT-RIGHT's Avatar
Hmm... not sure about that,
The crankshaft is either
crossed drilled or the oil holes are drilled so that when the
cylinder fires the oil hole in crank is facing up torwards
the cylinder. Thereticaly Providing a Actual film of oil the
downward force of the rod bearing will ride on.
My Counter Crank was crossed drilled . It is a
Sonny Bryant Billet which is knife edged on the wrong
side telling me it started life in a normal application.
Dont really think it makes a big difference.
Providing there is enough oil pressure and proper clearence.
Next time I have a bottom end apart ill take note on where
the oil feed is for the rod bearings.
(Hopefull not mine)
Here is a recent Thread on it
Hope this helps
Gerry
http://www.offshoreonly.com/forums/s...unter+rotation
KNOT-RIGHT is offline
Deltarat
Drives and Lower Units
2
03-13-2008 07:55 PM
BOOSTEDSCARAB
Chris Craft
4
07-15-2005 05:54 PM
foothill
8
07-01-2005 12:03 AM
jerosejr
58
03-15-2005 07:59 AM
