598ci Dyno Numbers
Old 07-15-2005 | 10:13 AM
FASTERDAMITT's Avatar
Default 598ci Dyno Numbers
598 Going in the Superboat this weekend. Just run the dyno last night. What do ya think?
Attached Thumbnails 598ci Dyno Numbers-dyno-001-large-.jpg   598ci Dyno Numbers-598-large-.jpg
FASTERDAMITT is offline
Old 07-15-2005 | 10:20 AM
Wobble's Avatar
SORE MEMBER
Default Re: 598ci Dyno Numbers
Great numbers, I'll bet you are pleased. It's going to be hard on the drive though.
Wobble is offline
Old 07-15-2005 | 10:24 AM
Stormrider's Avatar
JC Performance Engines
Nice power. You should be running real fast!
Stormrider is offline
Old 07-15-2005 | 11:13 AM
jdnca1's Avatar
Very impressive for hydralic roller motor and mufflers! What timing did you end up running ~32ish? How big is the Dominator?
I would've like to seen what happened on a pull to 6400.
Do you think the oil pan is big enough?
jdnca1 is offline
Old 07-15-2005 | 11:23 AM
Carb is a 1050. I'm not sure of the timing. I'll have to look. Valve covers and pan are "one off" built for my engine.
Old 07-16-2005 | 12:14 PM
Strip Poker 388's Avatar
Rob
Nice #'s!! The oil pan looks like a Billet Fabrication pan.
Westtech is one of the best in the country,Good choice
Good Luck
Rob
Strip Poker 388 is offline
Old 07-16-2005 | 12:40 PM
dykstra's Avatar
impressive
dykstra is offline
Old 07-16-2005 | 02:11 PM
Rob
Originally Posted by JC performance engine
Keep a close eye on that balancer you have.I had one come apart on me.You should try a HVH supersucker carb spacer.Its worth about 10 to 15 HP.
What kind of ballance it that ?? I dont reconize it.
Old 07-16-2005 | 02:12 PM
Thumbs up Re: 598ci Dyno Numbers
NO REPLACEMENT FOR DISPLACEMENT!! Great numbers for an N/A motor. Should be a screamer in your boat when dialed in. Good Luck!
Ray @ Raylar
Raylar is offline
Old 07-16-2005 | 06:21 PM
Very Nice! I like the "relatively" mild cam made possible I'm guessing by excellent head flow numbers.
tomcat is offline
