Can any damage happen by torq'n heads to tight? >
Old 07-16-2005 | 05:27 PM
vandeano's Avatar
Default Can any damage happen by torq'n heads to tight?
When I installed my heads on my 502, I went by the torque lbs. that where stated in my Mercruiser manual (92 lbs). The bolts where new ARP. ARP instructions read "torque to 62 lbs" when using there lube.
What could be the worse scenario my torquing to 92 lbs.?
vandeano is offline
Old 07-16-2005 | 11:16 PM
R Addiction's Avatar
AT Cult Member #3
Default Re: Can any damage happen by torq'n heads to tight?
crushing the head gasket.......
R Addiction is offline
Old 07-17-2005 | 12:27 AM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
worst case if you used their lube:
-overstretch/stress head bolts reducing bolt elasticity
potentially causing early bolt failure
-causing it very difficult to remove in future removal especially if heads got hot at any time
-(potentially) early head warpage if alluminum heads and torque sequence was suspect and heads got hot
GoCiggie31 is offline
Strip Poker 388
03-19-2006 04:24 PM
