Bouncing Tach
Old 07-18-2005 | 11:14 AM
onesickpantera's Avatar
Default Bouncing Tach
At higher rpm my tach starts bouncing. It's on the money and steady until about 4500 rpm. When I am trimmed out and running 5000 rpm it's all over the place. I replaced the tach and the new one does the same thing?
Looked for the obvious loose wire and found nothing. Could this be a sign of a bad ground?
onesickpantera is offline
Old 07-18-2005 | 11:27 AM
BAJA342's Avatar
Charter Member #1251
Default Re: Bouncing Tach
Are you hitting the Rev limiter? My old Checkmate would bounce at wot when it was hitting the limiter?
BAJA342 is offline
Old 07-18-2005 | 11:31 AM
Not hitting the limiter, checked it with a tach that clips around a spark plug wire and I was right at 4950-5000 rpm when trimmed out. It starts at about 4500 and gets worse as the rpms increase. Under 4500 it's steady and accurate.
Old 07-18-2005 | 11:32 AM
GOODT's Avatar
CHECK THE DIST CAP A BAD CAP WILL CAUSE TACH TO JUMP
JOE
AMERICAN PERFORMANCE MARINE
410-573-0057
[email protected]
GOODT is offline
Old 07-18-2005 | 11:33 AM
Okay, now I'm gonna sound stupid but I don't think my motor even has a distributor?
It's a 2003 Volvo Penta 5.7 GXi
Old 07-18-2005 | 11:34 AM
BillR's Avatar
OSO Moderator
Mine does the same. Merc 575SCi
replaced cap & rotor same problem.
Still looking for a cure too
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-18-2005 | 11:50 AM
Tantrum's Avatar
Mine was doing that last weekend. Spent about an hour touching every connection and trying to move every wire. I didnt find the loose groung I was looking for but when I ran the boat this weekend it was dead on. one of the plugs on the wiring harness must have been loose.
Tantrum is offline
Old 07-18-2005 | 12:56 PM
same problem on my playboy
dreamer is offline
Old 07-18-2005 | 01:12 PM
"prongs of the cannonball plug"
you mean the doohicky in the whatcha-ma-thing?
laymans terms please... or ill just tell my boat wrench-a-thingy guy
dreamer is offline
Old 07-18-2005 | 01:24 PM
OBNOXUS21's Avatar
I had the problem and the electricals shut my motor down. Ended up re-wiring the port side ignition and something near the distributor
OBNOXUS21 is offline
