Bravo Gear Lube Hours????
Old 07-20-2005 | 08:47 PM
Default Bravo Gear Lube Hours????
Under mostly hard driving, with 700 hp, how often should the gear lube be changed???
ActiveFun is offline
Old 07-20-2005 | 08:54 PM
Outdrive1's Avatar
Masher touches my
Default Re: Bravo Gear Lube Hours????
50 hours seems to be the standard, under hard conditions why not 25? When do you do your oil?
Outdrive1 is offline
Old 07-20-2005 | 10:35 PM
JC's Avatar
JC
Amsoil every 20-25 hours
JC is offline
Old 07-21-2005 | 02:24 AM
700hp and hard driving, I would be doing it every 20hrs.
Griff is offline
Old 07-21-2005 | 08:42 AM
mr_velocity's Avatar
Redline Heavy shockproof every 25 hours.
mr_velocity is offline
Old 07-21-2005 | 08:56 AM
I change the engine oil approx every 10-15 hours
Old 07-21-2005 | 09:18 AM
HABITUALVIOLATR's Avatar
Amsoil, Every 15-16 Hours. Cheap Insurance.
HABITUALVIOLATR is offline
Old 07-21-2005 | 09:30 AM
OldSchool's Avatar
25 hours
OldSchool is offline
Old 07-21-2005 | 10:23 AM
Airpacker's Avatar
I change mine out every 15 hrs. Better safe than sorry. It also lets you count the metal fragments stuck to the drain plug.
Airpacker is offline
Old 07-22-2005 | 04:52 AM
Strip Poker 388's Avatar
Rob
Amsoil every 25 hours w/925hp
Strip Poker 388 is offline
