who sells raw water pressure releif valves >
Old 07-22-2005 | 05:11 PM
ratman's Avatar
Default who sells raw water pressure releif valves
i called trick and he doesn't have any in stock. was wondering who makes them? who has them? i would like to plumb mine of the kpm strainers i got from fred as i have one large and one small port that are not being used. thx in advance for any info, ratman
ratman is offline
Old 07-22-2005 | 05:48 PM
RLW
Default Re: who sells raw water pressure releif valves
You have to plumb after the seawater pump and before the engine.
Get it from Mercury. Do a search to get the part number or maybe somebody will post the part number for you.
RLW is offline
Old 07-22-2005 | 06:17 PM
ratman's Avatar
is merc the only manufacturer for these? thx ratman
ratman is offline
Old 07-22-2005 | 08:03 PM
ratman's Avatar
ttt
ratman is offline
Old 07-23-2005 | 04:47 PM
ratman's Avatar
any of riggers want to help i guy out? who else makes a pressure relief valve for the raw water plumbing? thx in advance
ratman is offline
Old 07-24-2005 | 10:16 PM
rbtnt's Avatar
I used something like this, but I think mine have a smaller adjustment range. This one is adjustable from 0 - 300 psi.
http://www.grainger.com/Grainger/pro...543225&ccitem=
rbtnt is offline
Old 07-24-2005 | 10:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
http://www.cpperformance.com/detail.aspx?ID=521
This is for a 1/2" valve. I tried one a couple yrs ago, wasn't large enough. I seen the same valve but in the 3/4" version. These are WATTS brand valves that are sold by Teague and CP for a bit more $$ than what can be purchased thru elsewhere. I seen them in the area of $30.
WATTS 530C
Not sure about the high pressure rating numbers, other than my 1/2" was fully open at only 20psi according to my dash gauge.
US1 Fountain is offline
Old 07-25-2005 | 05:14 AM
I believe where the size is listed as 1/2 to 3/4 it is the discharge size. They are still only 1/2 on the goes into end. You can use two of these. Set one at a slightly lower pressure than the other. I ended up with two and it works perfectly. The lower pressure one is open most all of the time and the higher pressure opens at higher RPMS. By balancing the settings you can achieve 5lbs. at idle and 15 at WOT.
BadDog is offline
Old 07-25-2005 | 08:56 AM
BZ's Avatar
BZ
Got mine from Eddie marine. just put them on last week and they work great....
BZ is offline
Old 07-25-2005 | 11:39 AM
cougarman's Avatar
Here's a link for ya.............
Water Pressure Relief Valve
Cougarman
cougarman is offline
