whats do huge tabs do for the boat? >
Old 07-22-2005 | 08:26 PM
ratman's Avatar
Default whats do huge tabs do for the boat?
was looking at the old school cig race boat chatam racing just bougt to restore (where have all the old raceboats gone thread) and the tabs on that thing are at least twice as big as the ones on my 35 cig. what is the benifit of the huge tabs? does a longer tab make your boat ride out as though it were a longer boat? thx for any info, ratman
ratman is offline
Old 07-22-2005 | 11:26 PM
Quiet Storm's Avatar
Default Re: whats do huge tabs do for the boat?
You will appreciate the big tabs if you run in rough water or if the boat is propped for speed. They will help to hold it or get the bow down.
Quiet Storm is offline
Old 07-23-2005 | 12:15 AM
cigarette1's Avatar
Member #2 ....Jeeezz
Rough water ??? I don't think more than a handfull of people here can appreciate rough water.
cigarette1 is offline
Old 07-23-2005 | 12:33 PM
Strip Poker 388's Avatar
Rob
I put the bigger ones because the tips are narrower. I dont have to put the down as far when its at 100 to stableize it as much
http://www.offshoreonly.com/forums/s...highlight=tabs
Strip Poker 388 is offline
Old 07-23-2005 | 12:39 PM
Bad Girl's Avatar
the wide tabs provide more running surface to prevent chine walk at high speeds when the hull gets up out of the water
47 Lightning SE
Bad Girl is offline
Old 07-23-2005 | 11:33 PM
MnFastBoat's Avatar
Charter Member#157
I can say for my twin engine 28' cat it made a BIG difference
Ewnt from a 15" tab under the notch to a 30" tab on the transom
Basically added 2'+ to my boat.
I can plane slower, carry a load better and top end not effected at all.
Attached Thumbnails whats do huge tabs do for the boat?-2005_0412image0023.jpg   whats do huge tabs do for the boat?-2005_0424tab0031.jpg   whats do huge tabs do for the boat?-2005_0503home0010.jpg
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 07-23-2005 | 11:37 PM
ratman's Avatar
those new blue tabe look sweet!
how long are they what did they cost and where did you get em? thx in advance for info, ratman
ratman is offline
Old 07-23-2005 | 11:38 PM
ratman's Avatar
is there only one in the middle on your cat? why not a tunnel tab?
ratman is offline
Old 07-24-2005 | 12:02 AM
Poorsche's Avatar
THink I posted this somewhere else but--
Was it totally necessary to make the cuts? I'm plannig smae conversion on a FOrmula SR357 with TRS drives.
Poorsche is offline
Old 07-24-2005 | 06:42 AM
MnFastBoat's Avatar
Charter Member#157
Single Tab
measures 16 " at the transom, about 12" at the end and 30" long
Ram housing is bigger then my arm
Trick Marine, who else is there
It is Dana Marine Monster Tab.
