Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Painting drives while on boat? >
Old 07-23-2005 | 09:03 PM
jec1521's Avatar
Default Painting drives while on boat?
Can I paint the drives while still on the boat? or is it worth it just taking them off? Also, if I were to take them off, do i NEED a drive stand and how hard is it to take them off. I have never taken them off before.
jec1521 is offline
Old 07-24-2005 | 01:51 PM
CMG's Avatar
CMG
Default Re: Painting drives while on boat?
Originally Posted by art kern
yes you can , but you will have to do some masking off . i have painted a lot of drives , both ways . i think that you will find it twice as easy , with the drives off the boat , unless you are using a spray bomb , i spray most drives in imron with a gun ,either way you will have to mask off unless the drives are off the boat . and no you do not NEED a drive stand . i usually hang the drives from a 4x4 or anything that will handle the weight . / A . K . A . /
What do you mean by hang? off a plow frame??
Chris G.
CMG is offline
Old 07-25-2005 | 01:43 PM
RUSSSR1's Avatar
No not the plow fram, just drill the passenger door and put the inside transom plate on in a way that you can still get to the door handle
I think he ment a 4X4 as in wood
RUSSSR1 is offline
Old 07-25-2005 | 01:51 PM
SUPERSTITIOUS's Avatar
Lol!
SUPERSTITIOUS is offline
Old 07-25-2005 | 02:41 PM
CMG's Avatar
CMG
ugh - Ok, guess I'm just a dopey country boy from NH.
Every time I see some one here talk about trouble with their heads I assume they mean their wife and her sister too
Chris G.
CMG is offline
Old 07-25-2005 | 02:42 PM
CMG's Avatar
CMG
Russ your lucky you quoted me in your reply or I'd delete the evidence in a heartbeat!
Chris G.
CMG is offline
Old 07-25-2005 | 03:08 PM
CMG's Avatar
CMG
thank you !!!! i sometimes can not understand how somebody , can ask a question like that , or maybe he should just put a rope around his neck, and HANG himself . / A . K . A . /
Take it easy there Sparky....I'm sure the heat in the garage or the fumes from the paint are getting to you
Chris G.
CMG is offline
Old 07-25-2005 | 11:21 PM
RUSSSR1's Avatar
Sorry Chris but I had to bust your balls on that one
RUSSSR1 is offline
Old 07-26-2005 | 05:51 AM
CMG's Avatar
CMG
That one goes down as a top ten blunder for the year - I wouldn't have passed the opportunity up myself!
Chris G.
CMG is offline
Old 07-26-2005 | 10:17 AM
fund razor's Avatar
Don't know what kind of drives.... but if you are gonna keep this hobby... get a buddy to show you how to remove and replace your drives.
There are little "tricks" for each type drive.
(Like put your alpha in forward.... etc.)
fund razor is offline
