Cavitation Plate and Blade Flex= broken prop >
Old 07-24-2005 | 04:36 PM
mavrick10's Avatar
Default Cavitation Plate and Blade Flex= broken prop
I'm having a little problem. I've broken 2 props now and it's due to the blades flexing and barely grazing the cavitation plates. You can see on the bottome of the plate where the blade has barely come into contact with it. These were both 15 1/4 " diameter Bravo 1's. I've just ordered some 15 1/2 " Herrings so this is kind of worrying me a little. Should i take off the cavitation plates?? Or will the boat be too hard to get on plane?? Any suggestions?
mavrick10 is offline
Old 07-24-2005 | 06:34 PM
Default Re: Cavitation Plate and Blade Flex= broken prop
you could take off the plate planning time will increase very minamal if it is a problem then try the new maximus props from merc.
ssm-v1 is offline
Old 07-24-2005 | 11:36 PM
TablerockToy's Avatar
You should be just fine with the new props. Im assuming your running bravo drives? they can run up to a 16" prop with no contact. If you would put up a pic of the damage I could probably tell ya whats going on, But just taking a educated guess Id say that the stepped bottom of your boat is flexing the props, they are cracking(fairly common) and hitting the cavitation plate as they are braking
Later CJ
TablerockToy is offline
Old 07-25-2005 | 06:49 AM
JC's Avatar
JC
I lost a plate once (took out the prop) the boat was a pig to get on plain... Prop broke would break loose very easy.
JC is offline
Old 07-25-2005 | 07:30 AM
Official OSO boat whore
The boat will definetly cavitate with a high x-dim when planing. My boat has the cavitation plate bolted on and I once forgot to reinstall it. I couldn't even plane off. Put the plate back on and boat poped up with only a little slippage. It all depends on the hull, x-dim and prop. With a deep drive, I could see there being no difference.
My guess would with the Herrings being stronger that you won't be flexing the blades as much.
Cord is offline
Old 07-25-2005 | 08:29 AM
ONESICKGLADIATOR's Avatar
45 Lip Ship / 900 Zul's
Check your prop shaft in your drives to see if it is out of wack
Rick OSG
ONESICKGLADIATOR is offline
Old 07-26-2005 | 11:39 AM
Sydwayz's Avatar
Forum Regulator
Been there!! I actually had the prop blade begin to tear, and sliced the cavitiation plate, anode, and drive shower up. Say hello to a replacement lower case (B1-XZ appliaction).
Attached Thumbnails Cavitation Plate and Blade Flex= broken prop-all-three-broke.jpg   Cavitation Plate and Blade Flex= broken prop-cav-plate.jpg   Cavitation Plate and Blade Flex= broken prop-first-look.jpg
Sydwayz is offline
NJgr8ful
2
09-07-2008 11:51 PM
NJgr8ful
09-06-2008 11:03 AM
NJgr8ful
Swap Shop
0
09-05-2008 07:45 PM
JON242
1
09-09-2004 04:21 PM
txboater
8
06-17-2002 11:12 PM
