Head Liner
thats a tough one. unfortunately most headliners are made so they cant be removed without ruining it. is it glued up or stapled up under tension? any pics?
08 OPA High Points Champion
There Seems To Be A Gap Between The Headliner And The Deck,no Snaps Nor Screws,ther Is Some Disco Lighting Though Were It Might Seprate,ill Try And Send Some Pictures
wow! . . great lookin boat. is that a factory job or was it done up like the P-29's. either way that is way cool. just curious because i have never seen a 38, only the 29's.
some times the manufacturer uses those light strips to hid the tack rail that holds the headliner up. problem is that if you take the staples out you dont have anything to grab on to to re-streach it when re-instaling the cloth. when they do it at the factory they streach it first than trim off the exess. i have a friend that has a standard 38 Scarab of the same year. i will try an get a look at it an see if i can come up with anything.
Thanks,i Would Realy Appreciate That!it Is A Factory Job But There Arnt To Many At All,they Did Alot Of P29s But Only A Handfull Of P38 And P43 If That,THERE WAS A Lot Of Ching Needed To Get One Of The Big Ones You Could Buy A Topgun Instead!this Particular Boat Was In Thr Middle East For A For A While Until I Got It
very cool ride for sure. there are actually 2 or 3 p-29's in my area (didnt they only make 29 of them?). i always thought that was a great boat, had no idea they took the theme to the 38's an up. any more pics? my friends boat has base power in it. how does your 38 run out with the 525's?
Dean Ferry
02-18-2005 11:31 AM
