extension box?
Official OSO boat whore
Having the prop back further also sets it deeper into the water when plaing off. Usually is the prop cavitation when planing that is the determaning factor when setting the x-dim. With the box you can now go significantly higher.
Just did my TG change from transom mounted TRS's to Ext. Boxes and No V's . Jury's still out on how much it improved. But then again I changed so much at one time (blower eng's,X dim's, weight) hard to say what did the most improvement................
The x-dimension is simply the depth of the prop in the water. Deeper for crusiers, working boats, ski boats, higher for speed boats.
