92 Baja 24 Bandit with 502 Mag >
Old 07-26-2005 | 10:06 PM
G Man's Avatar
Default 92 Baja 24 Bandit with 502 Mag
what should the top speed of this boat be and what brand and size prop is recomended?
G Man is offline
Old 07-27-2005 | 09:33 AM
JasonSmith's Avatar
Default Re: 92 Baja 24 Bandit with 502 Mag
72 w/ a mirage 23 if it has a 1:50 gear ratio.
JasonSmith is offline
Old 07-27-2005 | 09:45 AM
mcourson's Avatar
I have a 91 with 454 Mag.
1.36 gears and 21P Mirage Plus.
Runs in the high 60's. I have never gps'd it but ran next to someone who had theirs and was running 66 with some trim left in it.
mcourson is offline
Old 07-27-2005 | 05:03 PM
I had a 91' ( 15* deadrise) with
a 502, 1.36:1 ratio drive.
It came with a 23 mirage ( this was
before the mirage + existed)
I put a 24 turbo on it, it ran a little
faster than the mirage.
In stock form it ran low 70's on radar.
I did try a hyromotive intimidator 4 blade....it didn't
like it.
If you have 1.5:1 gearing, you may have
to go up to a 25.
JaayTeee is offline
Old 07-27-2005 | 08:02 PM
G Man's Avatar
Have 1.50 ratio drive. HAve a 21 mirage on it now. Low end and planing is great.
Have a :
21 Tubo modifiled to be more like a 22
23 Mirage Plus
25 Mirage.
What RPM range should this motor max between? Also when will the Rev limiter kick in?
G Man is offline
Old 07-27-2005 | 09:26 PM
JasonSmith's Avatar
5100 +/- 50 rpm, I think. What are you seeing now? I would def. try the mirage plus. I think that boat will swimg a 23...?
Old 07-28-2005 | 11:12 AM
mcourson's Avatar
With the 21 my doesn't plane worth sh*t if I have more 2 people in the boat. That's with the tabs down.
It accelerates in the upper rpm ranges good. Can turn that 21 up to 5000 +- some rpm.
mcourson is offline
Old 07-28-2005 | 05:48 PM
G Man's Avatar
must be the 1.36 drive. Mine planes in about 2-3 seconds with no tabs with the 21. It will rev to 5200 - 5400 though. Too high. going to try the 23 Mirage Plus this weekend.
G Man is offline
Old 07-30-2005 | 09:09 PM
G Man's Avatar
put the 23 Mirage on and could not get good top end numbers do to conditions.
at 3800 RPM the speedo (Faria) was reading 40 MPH
Boat seemed to porpose at bit also. Usually doesn't. Could it be the prop?
G Man is offline
jdevelop2
06-01-2007 06:04 AM
Gordo
04-19-2007 09:16 AM
chevalcabre
Baja
14
09-06-2006 10:07 AM
G Man
Baja
23
09-25-2005 08:46 AM
G Man
Prop Talk
9
08-04-2005 05:23 PM
