Need a Merc fuel pump - got one? >
Old 07-29-2005 | 07:22 AM
BillR's Avatar
OSO Moderator
Default Need a Merc fuel pump - got one?
I need a Merc fuel pump. Part # 842429T
Merc has come out with a superceded part (don't have that #) I do NOT want the new part, I want to old version.
This fuel pump is the type that mounts to the sea water pump.
Anyone have this? I need one (maybe two)
I have the new type, and I don't think they pump as much fuel as the old ones.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-29-2005 | 09:07 AM
Wobble's Avatar
SORE MEMBER
Default Re: Need a Merc fuel pump - got one?
If you need more flow, cp sells this mod for your type pump http://www.cpperformance.com/detail.aspx?ID=939
I have made this upgrade on a 509 560hp bbc for a buddy with the carter m61045. It works fine. You just swap out the valve body. Or you can use the M5901P which allows you to use your stock lines (the pump arm is not the same as a block mounted pump, so you cant use the whole pump) http://store.summitracing.com/defaul...h.asp&N=400415
If you buy the carter BBC pumps make sure they have six screws holding them together round the edge. I think they all do.
CP's mod looks very much like the m61045 pump valve body.
Wobble is offline
Old 07-29-2005 | 09:11 AM
Strip Poker 388's Avatar
Rob
The CP pump says in there description
estimated 120 GPH
Strip Poker 388 is offline
Old 07-29-2005 | 09:19 AM
Wobble's Avatar
SORE MEMBER
Strip,
I just edited my last post. I found the box for the Carter pump I used, the m61045.
Doubt their flow numbers, but it pumps plenty for 560hp, no need for a fuel regulator.
Wobble is offline
Old 07-29-2005 | 10:08 AM
Rob
Originally Posted by Wobble
Strip,
cool
Yea i dont like when they say estimated on egines
Old 08-06-2005 | 08:38 AM
Bill, Hi Ihave a similar problem. I do not have the proper fuel pump to mount to the seawater pump. I am trying to avoid electtric pumps and wanted to do this upgrade to feed my 565's. Any help would be great. Dave H.
nightmoves is offline
Old 08-06-2005 | 04:43 PM
KCHOTBOAT's Avatar
Charter Member #737
It is I have one from CP and one I picked up a a speed shop. The speed shop one was half the price also.
KCHOTBOAT is offline
Old 08-06-2005 | 06:45 PM
Wobble's Avatar
SORE MEMBER
Cool,
Ive been thinking that for a while, nice markup for CP
Wobble is offline
Old 08-06-2005 | 11:23 PM
Outdrive1's Avatar
Masher touches my
How about the fuel pump off of the 500 efi's and the 575 sc's? Its part number 849930T1. I don't know it thats the part number you got for your superceeded part but you'd think if Merc sells that for 575 hp it should be good for your application.
Outdrive1 is offline
Old 08-06-2005 | 11:35 PM
buy the cv products billett pump fits the sea pump 8psi at full throttle its kind of pricey but all fuel problems solved fred at trick sells them.
rocket ronnie is offline
