procharger - headgasket where do they fail? >
Old 07-31-2005 | 09:58 AM
Default procharger - headgasket where do they fail?
I have a recently installed (100hrs) M-1 on a 7.4 MPI (500hr total time) 5# psi and cylinders 3,4,5,&6 are now 100#s as opposed to 120-125#s on 1,2,7,&8. When these stock head gaskets fail where do they fail most often? I also have pressure pushing oil out the dip stick @ high RPM.
baronbob is offline
Old 07-31-2005 | 10:39 AM
articfriends's Avatar
Default Re: procharger - headgasket where do they fail?
Bob,was nice meeting you at your beach party after sotw. You have not lost a head gasket,you'd be burning water or have close to zero on a cylinder. Your stock rings are giving up the ghost. I originally put my m-3 procharger on my origianal 502 5 years ago at 50 hours. At the time i went thru the motor and got rid of the metric ring j/e pistons that came in my 502 and put std ring pistons in w/j/e moly rings. I ran that combo for 3 years which was 185 hours and one year too long! by the middle of the 3rd year i was pushing oil out of the dipstick,breathers and every gskt on the motor.It started using a qt of oil every 5 hours and by the end of that 3rd season it used a qt of oil every hour between burning it and leaking it. That motor went from 150-160 lbs per cylinder to about 100-120 lbs per cylinder in 3 years and had lost 3 mph at end of 3rd season. The rings were soft when i pulled them off the 502 pistons and were beveled like crazy on the face,i ran it hard and it was probably a little lean somewhere too. I'm sure if you did a leakdown test it would be in the 35-50 % range omn the weak cylinders. If your 454 already had some hours on it before putting the blower on it than your probably at same point i was. I used zero gap rings on my 540 originally and this second time too,pulled it out at 138 hours after 2 hard seasons and it was just starting to burn a little oil and getting moderate blow by.These things you read about motors going 400 hours with a blower on them in my opinion are bs unless the motor was hardly pushed into boost,i think its time for you to freshen your motor at end of season,Smitty
articfriends is offline
Secretformula
12
08-06-2008 07:07 AM
Secretformula
3
07-26-2008 07:12 AM
zahndok
15
02-22-2008 12:38 PM
baronbob
1
07-24-2005 06:40 PM
