Tube towing bridle
I need to locate a tow rope bridle so my daughter can go tubing before she shoots me (if I can keep the boat running that long). With the twins and bracket I need one at least 16' long eye to eye. Problem is the only ones I've seen so far are only 12', which would leave it rubbing on the motor cowls pretty tight.
Anyone know where I might be able to locate a longer one?
Thanks - Greg
Thanks - Greg
I don't think I want a steel one incase it rubs against the motor cowls. I may try putting a longer line on one of the nylon ones if it looks like I can easily undo/redo the end attach (I'm not very good at back-braiding lines).
-Greg
-Greg
I have the whole setup- Tube (with pump), tow rope and bridle, if you are interested.
Edit: I just noticed the length you were looking for. I would have to double check what I have.
