Trailer Problem, Levelers between axles arent working >
Old 07-31-2005 | 10:06 PM
BajaRunner's Avatar
Default Trailer Problem, Levelers between axles arent working
My trailer has been making a clunking sound.
Here are a few pics. I had to jack it up to make the axle leveler (or whatever that thing is) work. The pics after that show what its like normally. what do you do to fix it? both tires are aired up good. the other side is fine. When it does move, its not smooth at all, real jerky, are there bushings in there that wear out?
Attached Thumbnails Trailer Problem, Levelers between axles arent working-trailerbad.jpg   Trailer Problem, Levelers between axles arent working-trailerbad2.jpg
BajaRunner is offline
Old 07-31-2005 | 10:07 PM
BajaRunner's Avatar
Default Re: Trailer Problem, Levelers between axles arent working
Now heres what it looks like normally. What causes this and how do i fix it?
Attached Thumbnails Trailer Problem, Levelers between axles arent working-trailerbad3.jpg
Old 08-01-2005 | 03:47 AM
cig1988's Avatar
Bolts too tight?
cig1988 is offline
Old 08-01-2005 | 12:46 PM
Wobble's Avatar
SORE MEMBER
Looks like front of trailer too high/low, if trailer frame parallel to ground with all same size tires/pressures then suspension should be even too.
Only known cure is this
Attached Thumbnails Trailer Problem, Levelers between axles arent working-torque%2520flex2.jpg
Wobble is offline
Old 08-01-2005 | 12:50 PM
Official OSO boat whore
Something is causing that axle to twist under the trailer. Out of level would seem to be a likely cause. There are bushings in there that can easily wear out. I found on my trailer those idler link bolts were actually cut in half. I ended up needing new links, bolts, idlers, bushing, etc. When you do replace the parts, get the bolts that can be greased. A little grease will add significant life to your suspension.
Cord is offline
Old 08-01-2005 | 04:49 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Non level will not be the cause of that picture, unless there are no tires on the 1 axle. You should be able to raise the tongue a couple feet and be no were near that picture. Kinda looks like the center hole may be worn off center, shifting the leverage point to the shorter side. Or a broken leaf?
US1 Fountain is offline
Old 08-01-2005 | 04:56 PM
BajaRunner's Avatar
I talked with roadrunner and sent them the pics, and there are 2 problems.
1. my shackles are backwards for some reason, (Driving off a curb or something)
2. My leveler's are worn, and need to be replaced, along with spring bushings.
hopefully that fixes it. the leveler does seem off center, like its worn.
Old 08-02-2005 | 08:39 AM
I had the same problem with a previous trailer. Mine would happen every time I used a particular ramp that had a significant drop off. When I pulled out, it would catch on the ledge, and roll the leveler, just like what your picture shows. When this would happen I would chock the tires and roll it back where it needed to be.
Island Hopper is offline
Old 08-02-2005 | 10:27 AM
mopower's Avatar
Toxic FORMULA
By the looks of the pix , you have some rust there. Could also be inside too and causing the "not smooth and jerky" movement you talk about.
mopower is offline
MILD THUNDER
2
09-07-2008 01:04 PM
pullmytrigger
1
12-02-2006 09:31 AM
MnFastBoat
6
08-02-2004 10:23 PM
MnFastBoat
6
04-18-2004 09:45 PM
euby
12
07-22-2003 08:42 AM
