496 HO cruising RPM >
496 HO cruising RPM
496 HO cruising RPM
Old 08-01-2005 | 07:27 AM
Default 496 HO cruising RPM
the 496HO's (stock) max RPM is 5000 what would be the the highest ideal cruising RPM for 2 hour runs at a time?
thanks
bezdikjack is offline
Old 08-01-2005 | 11:31 AM
GOODT's Avatar
Default Re: 496 HO cruising RPM
3800-4200
GOODT is offline
Old 08-01-2005 | 02:48 PM
Dave M's Avatar
Veteran: Navy
thanks
Ideal in terms of what? Fuel consumption, wear and tear, speed?
I would think you can run it at 4K all day long without harming it. You will be using al ot of fuel though. I usually run mine at around 3500 on long runs. Mostly because that yields a good cruise speed too.
Dave M is offline
Old 08-02-2005 | 08:44 AM
saubouin's Avatar
Go to Boattest.com and see if they have your boat & motor combo tested. They did for my Baja 242 with the 496 mag and it turned out the best "fuel efficient" cruising rpm was 3k.
saubouin is offline
Old 08-02-2005 | 04:27 PM
My Best Cruise Was At 4000 Rpm's In A 30' Cigarette Mystique. It Was In A Twin Step But It Returned A 1.2 Mpg At 65 To 67 Mph.
RICKY PEREZ is offline
Old 08-02-2005 | 08:52 PM
mwdill's Avatar
mine seems to be right around 3200-3400.
mwdill is offline
Old 08-02-2005 | 09:33 PM
i am not really looking for saving fuel, just what would be the highest rpm i can run the engines on for 2 hours at a time without causing any damage, or shortening the life of the engines faster than the life it should have under normal circumstances. for example can i run them @ 4200rpm for 2 hours without increasing the wear and tear too much or would that be the same like max rpm which is 5000
thanks
jack
Old 08-03-2005 | 10:09 AM
thanks
jack
anyone?
Old 08-03-2005 | 02:06 PM
boatfreak's Avatar
I'll jump in here though I don't claim to be an expert. I have a 2001 with 240 hours on it. I bought it new so I know how it has been run and cared for. I can't say I have ever run the 2 hours you are referring to but I have made several long runs at over 4000 and I feel very safe doing it. I don't think I would run a long time over 44-4500 but I would not worry about anything less than that. As long as you have good fresh oil in it I just don't think you can hurt these things.
boatfreak is offline
Old 08-03-2005 | 03:56 PM
blue thunder's Avatar
The gage that every boat should have and that would answer your question is an oil temp gage. Running extended high rpm distances without knowing oil temp is like playing russian roulette. You need this temp to stay below about 230f at cruise (whatever the rpm may be) to not shorten the life of the engine rotating assembly.
BT
blue thunder is offline
