Why Are My Batteries Connected? >
Old 08-03-2005 | 01:24 PM
TOMMY HIWAVE's Avatar
Default Why Are My Batteries Connected?
I Have Two Battery Switches But If I Cut Either Of Them Off Both Eng's St Ill Have Power. Could Something In The Dash Or Cocpit Be Running A Connection
TOMMY HIWAVE is offline
Old 08-03-2005 | 01:25 PM
Wobble's Avatar
SORE MEMBER
Default Re: Why Are My Batteries Connected?
Power to keep running or power to crank?
Wobble is offline
Old 08-03-2005 | 03:34 PM
both
Old 08-03-2005 | 03:36 PM
Official OSO boat whore
Something could be connected on the hot side of the battery switch, connected to the starter hot terminal or directly to the battery. Some boats are such a wiring nightmare that who knows were the power is back feeding from.
Cord is offline
Old 08-03-2005 | 03:42 PM
efi so i guess i have to fig it out thanks
Old 08-05-2005 | 10:40 AM
fund razor's Avatar
Sounds like the starters are wired direct to batteries + to me.
The main AC buss usually comes off of the starter.
The "right" way to wire the switches is batteries + to switch, and then switch output to starter.
fund razor is offline
Old 08-05-2005 | 11:07 AM
Wobble's Avatar
SORE MEMBER
Check this thread out. Is this what you have?
Wobble is offline
Old 08-05-2005 | 02:47 PM
forgot something the tread
Old 08-05-2005 | 09:23 PM
Outdrive1's Avatar
Masher touches my
It should be pretty easy to trace down, see whats bolted to your positive side of your batteries and trace them down. If they only have a run to the perko switch than you should be able to shut them off. If they have any other wires, (starter, alt, trim pump) then you could have power runnning off one of those for your motor. The standard 9 pin Merc harness runs power to you dash, that harness is probably connected to your starter or altenator.
Outdrive1 is offline
Old 08-05-2005 | 10:36 PM
Wobble's Avatar
SORE MEMBER
oops,
here it is http://www.offshoreonly.com/forums/s...ttery+switches
Wobble is offline
