Trailering Checklist
Old 08-04-2005 | 11:06 AM
saubouin's Avatar
Default Trailering Checklist
Tomorrow I'm towing my boat from Lake Anna to OBX, about 250 miles. Just trying to make sure I don't forget anything.
spare trailer tire
tire pressure gauge
grease gun
car ramps
wheel blocks
heavy duty jack
tools
transom tie downs
What else am I forgeting?
saubouin is offline
Old 08-04-2005 | 11:07 AM
bobonthis's Avatar
Default Re: Trailering Checklist
Boat
bobonthis is offline
Old 08-04-2005 | 11:12 AM
Tantrum's Avatar
Spare trailer wheel bearings greesed and ready to go.
I also like to carry a BIG ratchet strap in case you do lose a wheel bearing you can tie an up that wheel and limp it off the highway.
Been there, done that
Tantrum is offline
Old 08-04-2005 | 11:13 AM
bobonthis's Avatar
4-way Lug Wrench
Old 08-04-2005 | 11:22 AM
Indy's Avatar
Member #154
Originally Posted by rastaboatin
Boat
ROFLOL!!!
Indy is offline
Old 08-04-2005 | 11:33 AM
Donzi38ZX's Avatar
I also tie down the front with a ratchet strap in addition to the bow strap on the trailer. Keeps the bow from bouncing.
Donzi38ZX is offline
Old 08-04-2005 | 01:56 PM
PatriYacht's Avatar
A spare set of wheel bearings, races and seals. And the tools to change them. After a failure a couple years ago I always carry them.
PatriYacht is offline
Old 08-04-2005 | 02:12 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
What are the car ramps for?
I always carry some extra replacement lights too. The replacements are cheap, and well worth having if you need them.
WARPARTY36 is offline
Old 08-04-2005 | 02:15 PM
saubouin's Avatar
I did a search on how to change a flat tire on a trailer w/ torsion springs. One method was to drive the non-flat axle up on the ramp susepnding the axle with the flat tire in midair, thus making it easier than jacking everything up.
saubouin is offline
Old 08-04-2005 | 02:17 PM
WARPARTY36's Avatar
Makes sense. A 4x4 block of wood will do as well. It also comes in handy for chocks and a prop block.
