454 mag problem >
454 mag problem
454 mag problem
Old 08-06-2005 | 10:40 AM
liquid asset's Avatar
Default 454 mag problem
Its only running on like 4 or 5 cylinders, we've already checked all of the obvious, it happened all the sudden and compresion is fine, any clues?
liquid asset is offline
Old 08-06-2005 | 11:06 AM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Default Re: 454 mag problem
fuel or spark?
Check rotor/ cap for arching isolate dropping cylinders.
I had a problem with the shift interupt micro switch causing to shut down cylinders
GoCiggie31 is offline
Old 08-06-2005 | 11:07 AM
Dave_N's Avatar
EFI/MPI? Not much info to work with. A failure of one of the injector driver circuits will suddenly take out 4 cylinders. Just a WAG.
Dave
Dave_N is offline
Old 08-06-2005 | 07:21 PM
MPI, could both of you guys elaborate, because I did have a broken injector and a nuetrel saftey switch go bad, which is wired around right now
Old 08-06-2005 | 07:24 PM
only 92 hours also, we just had a head rework from a valve seat issue and now this?????? 6 weeks down and counting, there goes the summer
Old 08-06-2005 | 08:01 PM
Dave_N's Avatar
Need more info!
What year? VST or Cool Fuel?
Did the problem start immediately after reassembly from head work? Or did it run fine for a few hours, then developed a new problem?
Did you check for trouble codes?
What does "checked the obvious stuff" mean?
Have you checked fuel pressure?
Which cylinders are missing?
Dave
Dave_N is offline
Old 08-06-2005 | 08:18 PM
2000
cool fuel
It all happened at the same time, dropped a valve seat
plugs, wires cap, rotor all checked
fuel pressure 42-43
Im not sure which cylinders, but can find out tomorow
Old 08-07-2005 | 10:25 AM
I just got back from the shop and he said the shift micro shuts down 4 cylders to shift into gear and if I wired around the nuetrel saftey switch it is probably stuck in that mode, what do you think, we are trying to fix that now
Old 08-07-2005 | 10:33 AM
GOODT's Avatar
is it a Merc or Omc if Merc alpha or bravo?????? if alpha it has a shift interruptor if bravo it does not. only Omc shuts indv. cyclinders Merc grounds the coil for a milisecond.
GOODT is offline
Old 08-07-2005 | 10:47 AM
It is a Bravo, what does grounding the coil do
