525 SC Carb Flooding >
Old 08-08-2005 | 05:17 AM
34scarab's Avatar
Default 525 SC Carb Flooding
I have twin 525 SC's, 1997.
I think these have the 1050 dominator carbs on them (stock).
My port motor will fire up briefly, then, as the fuel bowls fill with fuel, it dies out, flooding I'm guessing.
I pulled off the flame arrestor and watched as I cranked it over and fuel is pouring out of the accelerator pump jets. It is the front jets and it pulses with the pumping of the fuel pump, if that makes any sense? Not supposed to be getting any fuel from these unless I move the throttles which works the accelerator pump lever, which I am not doing.
I piulled the front bowl off and made sure the float wasn't stuck by movig it up and down several times.
Help, any ideas?
Accelerator pump diaphragm?
Thanks,
Scott
34scarab is offline
Old 08-08-2005 | 06:08 AM
Strip Poker 388's Avatar
Rob
Default Re: 525 SC Carb Flooding
Sounds like a picse if trash in the needle and seat. making it stick open
Strip Poker 388 is offline
Old 08-08-2005 | 06:28 AM
Ted G's Avatar
I don't think those have power valves but if it does I would check the power valve for a bad diaphragm also. Either way it sounds like time for a rebuild.
www.cbpba.com
Ted G is offline
Old 08-08-2005 | 06:37 AM
Rob
A blown power valve want make it pour fuel out the boosters .This is probaly what he is seeing ?
A busted Accelerator pump diaphragm want let it make a pump shot out the squirters
Old 08-08-2005 | 07:00 AM
34scarab's Avatar
Here is what I have:
The fuel is poring out from the jests located right behind the bowl vent tubes, not the circular fuel supplies in the main body of the carb.
Sorry for my ignorance on carburetor anatomy!
I'll probably pull the carb and go through it, looking for trash or anything else I can find. Is there any way to check the power valve or the accelerator pump?
Scott
34scarab is offline
Old 08-08-2005 | 04:40 PM
carney's Avatar
I have a pair of them. You must have a blown power valve or a broken gasket letting in fuel. Pm me and I will walk you through the carbs. If they are set up right that motor will Idle blow 500rpm. You dont want them there but they will idle right down.
carney is offline
Old 08-08-2005 | 11:52 PM
vette131's Avatar
check your fuel pressure, no more than 8psi. check the float level at the sight glass or level plug. if the pressure is ok remove & clean the needle & seat assy. you don't have to take the bowl off, it it just unscrews out the top. clean it carefully, blow it dry with compressed air & it should be fine.
reinstall it & recheck the float level.
vette131 is offline
Old 08-09-2005 | 12:02 PM
The "jets behind the bowl vent tubes" sounds like the air bleeds to me. If that is the case it means you're getting too much fuel in the bowl. Either the float is set way too high or the needle and seat assembly is stuck open (poss. by a peice of dirt) or the fuel pressure is too high (more than 7.5 - 8psi) for the needle to handle.
First, check fuel pressure. If thats OK, try tapping lightly on the needle adjuster screw (right at the top end of the bowl) with like the handle of a screwdriver. This usually will dislodge any small piece of dirt that is stuck in between the needle and seat. If that don't cure it you need to check your float level. It may be that you need to change your needle and seat assembly. If your gonna go that route, it's probably your best bet to just buy a rebuild kit from Holley (I think they're less than $50.00) and get someone who knows Holley Dominator carbs to do the rebuild.
HARDCORE A/O is offline
Old 08-09-2005 | 09:04 PM
They do have front and rear powervalves. I 'm unclear as to where the fuel is coming from though.
A pic is worth a 1000words.
Griff is offline
Old 08-09-2005 | 09:17 PM
bdr67's Avatar
34 scarab, also check your float mine was full of fuel and sank which would not close off the needle valve.
bdr67 is offline
