Outdrive Upgrade
You should also install trim spacers in the trim clyinders to prevent them from tilting the drive too far, The XR has a bigger u-joint assembaly that will not allow the drive to tilt as far and can be damaged if th spacers are not installed. merc also says to change the u-joint bellows reataing ring. There is some agrument about this, I asked the instructor when I wne to Merc class last winter and he said that the reataing ring for the x series is jus a tiny bit thinner becuase in some rare situtions they were rubbing and tearing the ring out.
So it doesn't sound to hard. Long as the current location is good (x dimension??) I've done gimble bearings before. Anyone know what I would expect top pay for an XR drive?
