engine compression question >
Old 08-09-2005 | 08:57 PM
Default engine compression question
looking at boat with 1999 502 magnum MPI. compression on all cylinders is between 150 and 160 except for #4 which is 135. Is this a concern? 135 hours on motor.
sands3827 is offline
Old 08-09-2005 | 09:02 PM
GOODT's Avatar
Default Re: engine compression question
no, you are ok and within specs but I would do a leakdown test on that cyl just to be on the safe side!!!
GOODT is offline
Old 08-09-2005 | 11:28 PM
articfriends's Avatar
Stock 502 mpi's are notorious for one or two low cylinders,they use J/E pistons from the factory with metric low tension rings. My 2000 (for the 1 month in its life it was stock) used 1 quart of oil from day one every 5 hours. I complained to the local baja dealer and they did a leakdown,it had one weak cylinder. They pissed around for 4 months,let it freeze solid in there parking lot and i finally got disgusted with them and took it from them and pulled the motor myself then the games began,Smitty
articfriends is offline
paulsrx700
Powerquest
9
08-28-2007 08:54 PM
johnnyboatman
6
11-01-2005 07:53 AM
OldSchool
11
09-30-2005 07:23 AM
88 MACH 1
8
12-30-2004 06:07 PM
THRILLSEEKER
9
03-06-2003 08:53 AM
